Clogged Cat/Random Misfire
Old Sep 10, 2007 | 02:46 PM
Stl94LT1's Avatar
Will a clogged cat cause a random misfire code, or did what was causing the code clog the cat? It appears that the cat has broken up, and the car will barely run. Just doesn't get enough breath.
It's on a 2002 TA.
Old Sep 10, 2007 | 03:15 PM
2001NBMZ28's Avatar
If the code is P0300 you can look it up at gearchatter.com Stock cats are now covered under warranty for 10yrs/120K on the 00-02 LS1 F cars.
Old Sep 10, 2007 | 05:59 PM
Stl94LT1's Avatar
Thanks for the link!!
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
98-LS1Z28
Sep 8, 2015 03:12 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
zajones
Jul 30, 2015 02:18 PM
