100k Tune Up
Old Sep 9, 2007 | 01:53 AM
RxNupe's Avatar
100k Tune Up
I'm approaching 100k on my 02 WS6. Besides changing plugs, we else would you recommend? Right now the car is a stock daily driver and I'm not looking to add much power....at least not yet
Old Sep 9, 2007 | 08:11 AM
AL SS590 M6's Avatar
Moderator
Change all filters and the PCV valve.
Service the trans and the rear end.
Check the U-joints while under there.
Change the brake fluid, PS fluid, and engine coolant.
New accessory drive belts if they haven't been changed recently.
Old Sep 10, 2007 | 12:33 PM
RxNupe's Avatar
What about wires?
Old Sep 10, 2007 | 10:27 PM
MasterZ28's Avatar
nope, but you can clean & check the bat. wires at the ports.
Old Sep 11, 2007 | 12:59 AM
Bayer-Z28's Avatar
.. That's it right there.. The plug wires should be fine. I forgot what the resistance reading should be if you checked em w/ a DVOM.
Oh..maybe Replace the gas cap too.
Another thing I just thought of.. You could do the full seafoam treatment. Oil, Gas, and intake.. Wipe down the throttle plate.. I'm a stickler for that one. It helps your throttle response a LOT!
If you have questions, check this thread
http://www.ls1tech.com/forums/showthread.php?t=534376
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
