Changing oil pump, what else?
Old Jun 9, 2005 | 01:06 AM
ree9c1's Avatar
My oil pump crapped out on me so I need to replace it. What other mods should I get done. I'm assuming cam and timing chain? My car is stock and I would have liked to keep it that way. I probably would do a couple of bolt ons but now that I have to go into the engine what else should I do? valvetrain?
Old Jun 9, 2005 | 06:33 AM
teke184's Avatar
Re: Changing oil pump, what else?
not all that much has to be removed to swap the oil pump does it?
if you want to stay stock...stay stock.
now if you had to swap lifters like me (or so i thought i did)...than a mild cam would be logical.
i would say do the LS6 oil pump and maybe a new double roller timing chain. just to keep all that in good working order.
while you have things off i suppose you could put an electric water pump on, or an underdrive pulley
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
