Changing oil brands on an LS1?
Old Apr 17, 2004 | 12:12 PM
zachw1036's Avatar
I just bought a 2000 TA. The guy was using quaker state. I heard that mobil 1 synthetic was the best to use. Could I switch to that oil without any problems? I heard you could start to get leaks etc. if you switch oils. It has 25k on it.
Old Apr 17, 2004 | 12:20 PM
SSpdDmon's Avatar
I switched to Mobil 1 synthetic from the regular oil the dealer was using @ 45K miles. I'm at 56K now and haven't noticed any problems.
Old Apr 17, 2004 | 03:32 PM
gav'spurplez's Avatar
I use valvoline syntec blend, and change it every 3 months, since i only put 5-6k miles a year.
Old Apr 17, 2004 | 04:49 PM
Kataklysm's Avatar
Changing oil brand/weight/convential/synthetic will not hurt anything.
Old Apr 17, 2004 | 09:52 PM
FastrDamnit!'s Avatar
Lightbulb
Synthetic oils are designed to work with all other types of automotive oils and weights.
You should have no problems.
Old Apr 18, 2004 | 05:57 PM
Greed4Speed's Avatar
Only problem you may see is oil consumption. Synth has smaller molecules.
Mine never used oil while running the regular 5w30 Valvoline and I decided to try synth. Now is was a 1/2 QT low at 3k miles.
chevy95z28
Jun 22, 2015 09:28 PM
alliance12364
Mar 6, 2015 04:39 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Catmaigne
Dec 25, 2014 12:16 PM
Jul 4, 2005 05:00 PM
