Change oil light
Old May 28, 2003 | 06:59 AM
roadkillZ28's Avatar
Exclamation Change oil light
just curious is it come every 3000 miles or there is a sensor to
check the condition of oil ?
thanx in advance
Old May 28, 2003 | 08:44 AM
SFB767's Avatar
I've heard that it's not a counter to the 3,000 mile mark, but rather a tester to see how pure your oil is depending on your driving conditions.
Old May 28, 2003 | 12:48 PM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Smile
I respectfully disagree withSFB767;
I changed my oil at 4000 MI with Royal Purple 10W-30, drove it once, and had the oil change light come on. My understanding is that it comes on per miles driven.
SteveC
Old May 28, 2003 | 12:53 PM
Aklaim's Avatar
The computer will signal the oil change light when it thinks it is time. It gauges driving style, temp, and frequent of use and decided on when it should be changed. Not saying that its always correct, but its just to let you know that an oil change should occur soon.
Old May 28, 2003 | 01:34 PM
Capn Pete's Avatar
Smile
My "Change Oil" light seems to come on about every ~10,000 kms (~6200 miles)........in fact, it just came on today! I think that once it's reset, it bases how many miles are driven, what the temperatures and stuff are, and probably how hard the car is driven (high RPM driving vs. low RPM driving) and determines "theoretically" when the oil would be due. It's too bad that the dealer still insists on every 5,000 kms for oil changes though (for warranty) 'cause I'd rather do it every 10,000 if that's when the light says it's due.
Old May 28, 2003 | 05:12 PM
stik6shift98's Avatar
when i autotap my car it shows percent of oil.....so i guess there is a sensor or soemthing that determines that
Old May 28, 2003 | 07:05 PM
SSpdDmon's Avatar
Man...yall need to read your manuals more often. The answers for simple questions like these are in there. You just gotta look it up.
Old May 29, 2003 | 04:57 AM
SSpdDmon:
I dont think the manual has info like these
Thanx for ur replies guys ....
Old May 29, 2003 | 05:02 AM
u8dusst's Avatar
That thing isnt accurate at all. After 3K, my oil is definitely ready for a change, it doesnt come on. Unless GMs idea of time to change your oil is when your oil is black X 2.
transam_388
Mar 15, 2015 11:53 AM
jj71787
Jan 31, 2015 10:20 PM
Scottylt1
Jan 8, 2015 02:48 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
