Car Missing like bad gas! any other possibilitys????
Old Feb 22, 2007 | 08:17 PM
yzblue125's Avatar
my Z is acting very strange Im preety sure its water in the gas, The car runs perfect starts to bog down than clears up, loses power again, clears up, misses, clears up etcetcetc!!!! If its not gas what elese could it be???? Thanks Ohh yea code it threw was----Random multiple cylinder Misfires
Old Feb 22, 2007 | 08:55 PM
AL SS590 M6's Avatar
Moderator
With that code you are probably right.
Old Feb 22, 2007 | 09:54 PM
SSpdDmon's Avatar
You need to get a scanner to see what's happening. I'd point to O2 sensors or possibly the MAF sensor as the most likely source of your problems. If it starts fine and starts acting up about 2 minutes after a cold start, then it's more likely the O2's. The car switches to closed loop when the ECT reaches 92*F on cold starts. That's when the PCM starts listening to the O2's. If they flatline, then you'll run really, really fat. If they peg high, then you'll run really, really, lean. I'd pull a few spark plugs to see what they can tell you about what's going on in the motor. You didn't get any other codes aside from the misfire dtc?
Old Feb 23, 2007 | 06:49 AM
teke184's Avatar
unplug the maf sensor. if it smooths out than you pretty much know it's a sensor...
probably the maf or the o2s....as suggested
Old Feb 23, 2007 | 06:54 AM
Moderator
[QUOTE=SSpdDmon;4434668]You need to get a scanner to see what's happening. I'd point to O2 sensors or possibly the MAF sensor as the most likely source of your problems. If it starts fine and starts acting up about 2 minutes after a cold start, then it's more likely the O2's. The car switches to closed loop when the ECT reaches 92*F on cold starts. That's when the PCM starts listening to the O2's. If they flatline, then you'll run really, really fat. If they peg high, then you'll run really, really, lean. I'd pull a few spark plugs to see what they can tell you about what's going on in the motor. You didn't get any other codes aside from the misfire dtc?[/QUOTE]
That's why I didn't even suspect the O2s. It doesn't take hardly any variation in O2 function for them to set a code and he didn't mention O2 codes.
Could be MAF. Now MAF codes are the opposite. MAF can be almost dead and not set a code.
Old Feb 23, 2007 | 07:14 AM
yzblue125's Avatar
well since I have long tubes im always throwing those rear o2 codes, Yea it does exactly what one of yall said, at a cold start it runs fine for like a few minutes than it starts cutting up, im starting to think its a 02 problem cause I had to extend all those wires during the Longtube Install and maybe a connector came lose or something ill check.. Thanks Guys
Old Feb 23, 2007 | 07:20 PM
Moderator
Rear O2s have no effect on performance or the way the car runs.
Old Feb 24, 2007 | 09:48 PM
yzblue125's Avatar
I know the rear ones dont do anything. but i did extend the wires on the front ones.
Old Feb 25, 2007 | 06:02 AM
Moderator
But you posted
All I can go by is what you type. Sorry.
Old Feb 25, 2007 | 02:39 PM
yzblue125's Avatar
Fixed it.. Header burnt an o2 wire in half, Thanks Guys
Old Feb 26, 2007 | 10:06 AM
SSpdDmon's Avatar
Welcome...
cmdeshon
Dec 12, 2014 10:51 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
USAirman93
Nov 24, 2014 03:37 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
