Car Hesitates
Old Apr 26, 2007 | 04:25 PM
Mister Will's Avatar
Car Hesitates
I have been noticing for awhile the engine hesitates when I increase the throttle lightly. It doesn't happen when I'm more agressive with the throttle. After doing a search I noticed several threads pointed toward the coils. I haven't had a cahnce to scan it. However, there is no Service Engine Soon light showing. But it did come on several months ago, coded indicated O2 sensors. Then the SES light cleared itself. Recently it came back on (under heavy acceleration as before) then went out before I could scan it.
I'm just wondering. If it is the coils, how do I determine which one is bad?
Old Apr 26, 2007 | 05:00 PM
Kraest's Avatar
Retired
The coils don't typically go bad. It's probably an 02 sensor related thing:
The computer uses the programmed/stored fuel/timing tables under heavy acceleration and uses the oxygen sensors to maintain A/F under part throttle.
That's why it does that.
Scan it and see what history codes pop up.
Mike
Old Apr 28, 2007 | 05:02 PM
smithtim's Avatar
yeah you should still be able to see that code even if the SES is not lit up it will store them... mine will read out as pd##### , think is something like pending not active??
but if you got an O2 sensor code before I'd think that’s your cause
Old Apr 28, 2007 | 05:15 PM
I got a scan. Same codes as before; P0131 and P0151, O2 sensor #1 banks 1 and 2.
So where is the webpage that tells me how to change these out?
Old Apr 29, 2007 | 06:26 PM
Bayer-Z28's Avatar
I'm going to say a spark problem. Typically under a load it will sputter. But that's not your problem.
Have you checked the plugs? Gap?
Old Apr 29, 2007 | 09:01 PM
Changed the plugs at around 48K, other wise no.
Old Apr 29, 2007 | 09:13 PM
Kraest's Avatar
Retired
Unscrew them from your exhaust with an open ended wrench or something similar, unplug the electrical connections, remove. Reverse steps for new ones.
Mike
Old May 2, 2007 | 07:53 PM
WS6NIGHTMARE's Avatar
Mike
Dont ya wish everything was fixed this easily on these cars?!
Old May 2, 2007 | 09:14 PM
What I'm trying to figure out is how to get an open ended wrench in there?
Old May 2, 2007 | 09:18 PM
Are you serious?
Old May 2, 2007 | 09:33 PM
ReNxWar's Avatar
Mike
An open ended wrench won't really give you enough leverage. Go to autozone and rent a O2 sensor removal tool.
Old May 2, 2007 | 10:33 PM
Are you serious?
Yes. It looks like it would be easiest from underneath. Form the top looks like a tight squeeze. I simply want to know what is the best method before I put the car on jacks and go underneath.
jayblev95
Jan 20, 2015 01:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Queens94z28
Dec 20, 2014 09:11 PM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
