car heating even after new coolant
Old Jun 6, 2006 | 07:39 AM
  #16
AL SS590 M6's Avatar
Moderator
Re: car heating even after new coolant
Originally Posted by Lunch Box
If the low coolant light is still on after the system has been properly full the sensor is probably malfunctioning; it's either not working or perhaps there is a loose or broken wire at the sensor
Not exactly sure where to find the sensor for you to check but I'm sure someone can
The sensors are junk. In fact they were so bad that they quit using them in 2000.
Just ignore the light or if you can't a new sensor is around $40 from GM and it's located just below the upper radiator hose. It's a square little box with wires going to it.
As far as running straight water, don't do it for very long. Coolant has lubricants in it for the water pump and corrosion inhibitors and it raises the boiling point way above that of water.
If you want to stay with water as a coolant then get some "Water Wetter" or "Purple Ice" they also have the lubricants and corrosion inhibitors in them and will make your car run a little cooler.
Old Jun 7, 2006 | 12:35 AM
  #17
bmotwani's Avatar
Yeah thanks man. I think you got a point re. sensors, cos when there was a leak in the radiator and the car overheated to the max and stoped mid-road last month, the coolant light didnt even show up. But this saturday I will be going to fill in the coolant.
Old Jun 15, 2006 | 05:20 PM
  #18
DIYAR21's Avatar
yep.. l replaced my radiator and everything is fine now, temp. is fine now but light is still on and l dont bother.. before l put the sensor back on, l messed up a little bit and then l put back together and installed back to the car.. l am 99% sure my sensor is bad and yours too.. so dont bother..
Old Jun 18, 2006 | 04:21 AM
  #19
bmotwani's Avatar
Alrightey, the shop guy drained some of the water and topped the tank with coolant. Now i've got a well regulated engine and the coolant light doesnt show anymore. The temp occasionally goes to about 103/104 C which someone on this forum said was normal but not anything above that temp. As always, thanks for the advice everyone.
Old Jun 19, 2006 | 06:50 AM
  #20
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Cool Re: car heating even after new coolant
Originally Posted by 95GRNZ
Have you bled the system properly so that there is no air in the system?
Bingo!!, you still have air in the system, and probably a bad low coolant sensor.
SteveC
calaban
May 18, 2020 06:43 PM
Injuneer
Dec 15, 2014 09:36 AM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
cristian1311
Nov 23, 2014 02:22 PM
