car got hot yesterday
Old Aug 22, 2007 | 11:00 AM
DonutMachine's Avatar
on the freeway coming home from work, I noticed the needle up to about 200, scared me cause i never seen the needle that high(It never goes beyond the first hash mark even on hot days with the a/c on in traffic), I have a 160 t-stat(autozone), hypertech(to change fans), I recently flushed the system and added new dex-cool Orange i think. I had the A/c on but I do everyday, i pushed her a little and cut the A/c, then the temp came down, Should I be concerned. I drove her to work today, my commute is about 30 miles each way
Old Aug 22, 2007 | 11:38 AM
Kraest's Avatar
Retired
200 isn't even enough to boil regular water in a pot, besides the fact that you are using antifreeze and a pressurized system raises the boiling point of water greatly.
Besides... the temp gauges on LS1 F-bodies aren't very accurate, anyway
Old Aug 22, 2007 | 11:44 AM
i think i read somewhere that the 98 got a accurate temp reading, it still scared me, almost pulled over, killed my lt1 like that
Old Aug 22, 2007 | 12:20 PM
2001NBMZ28's Avatar
The '98 gauge actually works. If it just started happening after the flush and continues I'd check the easy stuff first, make sure all the air is out of the system, radiator cap is holding pressure. Is your low coolant sensor hooked up?
Old Aug 22, 2007 | 01:00 PM
yup, yes and yes
Old Aug 22, 2007 | 01:01 PM
i flushed it about 3 weeks ago
Old Aug 22, 2007 | 01:50 PM
Marc 85Z28's Avatar
The 98 F-bodies gauges ARE pretty accurate. But 200 degrees is nothing to worry about, even if it normally runs a little cooler. The boiling point of a properly maintained cooling system (good coolant, no air pockets, and a cap that holds pressure) is over 250F, but if you see it climbing up over 220, then you have a problem!
Old Aug 22, 2007 | 02:45 PM
a problem like what
Old Aug 22, 2007 | 02:54 PM
Marc 85Z28's Avatar
Originally Posted by DonutMachine
a problem like what
Leak/low coolant level
Bad thermostat
Air pocket
Incorrect coolant mixture
Inoperative cooling fans
Bad water pump
Clogged radiator
Collapsed hose
Missing serpentine belt
Faulty radiator cap
Point is, don't worry about why the car would run above 220F if it's not running above 220F. You stated you were running the car hard, in the summertime, with the AC on, and it was around 200F. I'd be more concerned if the coolant DIDN'T get a little warmer than usual.
calaban
May 18, 2020 06:43 PM
mr28
Apr 20, 2016 05:44 PM
Collector Car
Dec 17, 2014 01:12 PM
USAirman93
Nov 24, 2014 03:37 PM
mr28
Nov 23, 2014 11:11 AM
