Camber angle and alignment instructions.
I need to set the camber angel on my 2001 Z28 since it was lowered and I can see the inside of the tire is wearing. What angle should they be set at and how exactly do I adjust it?
Thanks,
Thanks,
You're probably better off just coughing up the $50 to get it aligned at a shop. Some of the new computer alignment equipment is extremely accurate and they can get it the way you want it. Just my .02
Had the same thing happening to me after I installed 2 1/2 inch drop springs. I haven't seen anything where you could possibly make an adjustment to the camber angle. I just went with 1 3/4 inch springs, the car handles better and the angle is fine, never had it adjusted.
Maybe you can adjust the angle without spending the money on adjustable control arms, maybe I overlooked something, just my 2 cents....
Aug 7, 2015 01:26 PM
93zder
Jul 14, 2002 05:17 AM
