cam question
Old Nov 30, 2003 | 01:05 AM
smokin30th's Avatar
Question cam question
got a couple of questions. 1- will the ls1 hot cam kit work in my 5.3 truck? 2- if so does anyone have an install guide on how to put a cam and valve springs on the ls1 trucks?3-and does anyone know if you have to pull the intake on the ls1 to change the cam? thanks in advance for replys
jason
Old Nov 30, 2003 | 08:39 AM
hrtbeat2's Avatar
All i know from what people have told me that the LS1 hot cam sucks. Not the power but Idling is bad, I would go with a com cam I have a 224/228 with a 581/589 lift on a 112LSA and it idles great with computer tunning, and it made on my Z 50+rwhp
Old Nov 30, 2003 | 08:48 AM
mcflyz28's Avatar
mine idles fine with no tuning,M-6
Old Dec 2, 2003 | 01:45 PM
HtownZ's Avatar
yes the hotcam will work for you, and on the LS1, unlike the LT1, you dont have to pull out the intake. I dont really like the hotcam, but its maybe a good choice for a truck.
Old Dec 2, 2003 | 03:37 PM
SSCamaro99_3's Avatar
I have been happy with my Hotcam. 381 rwhp/373 rwtq
Old Dec 4, 2003 | 08:03 PM
Taspeed's Avatar
Hey guys the ls1 hotcam isn't a bad cam but first off for a 5.3 liter it is going to respond very differently. First off the torque won't be as high due to less cubic inches...that is typical. Second, when the hell are you going to turn those kind of rpms in an automatic truck???? Granted if performance isn't what your after just sound...great! Just a thought and a suggestion. Don't use a hotcam. Look around a bit. You can get a better deal on a better cam suited for the 5.3. Look towards mti's cams, B1 for starters
Old Dec 5, 2003 | 12:37 AM
RS Dragster's Avatar
That looks about the same as what one of my buddies is pushing with his hotcam.
Had idleing issues at first, but just needed a little tune. Now you "almost" can't tell it's there.
Old Dec 5, 2003 | 05:27 PM
99BlackZ28T56's Avatar
My hotcam idles ok with stock tune. If I drilled the TB it would probably eliminate the hot start surging, but I'm just waiting to install the LT's so I can get a tune. I would avoid this cam with an automatic if not getting tuning. Having a stall converter would help though. I bought mine used(cam, springs and retainers) for $200 shipped from a guy that had it in his auto car. He said he had to drill the TB hole 1/4" just to idle, after tuning he had an "auto" cruise effect. If you buy used(I would do it again, saved $200+ship over new) just make sure to get everything checked before install. While not a "max effort" cam, if does make decent power as seen above. And has that noticable lope in the idle . The lower lift is nicer to the springs and doesn't have that sewing machine noise from the valvetrain.
EDIT: Thought I'd add that I had before and after dyno's without LT's(only changed the cam and pushrods). Below 5k rpm I only gained ~7rwhp 10rwtq. By 5700 rpm I was making ~25rwhp 25rwtq over stock with the stock tune. LT's and tuning should help dow low though.
Old Dec 5, 2003 | 09:39 PM
foff667's Avatar
the 112lsa wont like the auto in your truck and there are better cams out there for what trucks are used for...it will work but i cant say youll be happy performance wise because like others have said unless your spinning your truck to 6400 while towing it aint really worth it besides custom cams arent that expensive get somethign that will fit your needs. Also you dont need to remove the intake to do a cam swap.
lata
Bill
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
