Cam guru's.. a lil help please
Old Dec 30, 2007 | 11:16 PM
  #16
Kraest's Avatar
Retired
Originally Posted by SStrokerAce
Kraest, I've seen the same RWHP number out of a similar sized cam, 241 heads, a 9" with DR's FWIW.
It all depends on the setup. I've seen higher/lower on all kinds of different setups all across the internet. The setup I'm speaking of was done with a 2001 Z06 with untouched heads/intake, stock TB, no underdrive pulleys, Vette IRS, no dyno tricks, and on Futral's 248 Dynojet, which usually reads lower than alot of other internet dynos.
Mike
Old Dec 31, 2007 | 01:47 AM
  #17
89385formula's Avatar
Mike
Mike, I agree on most parts. New Era's dyno doesn't seem to let most lay down any spoiling numbers either. I can assure you no dyno games were played, since that was a prerequisite for the any shop I was gonna chose. Before too long here we will see what this car will do with the 10 bolt and normal street tires. I agree that the F13 is one of the most proven cams out there, and supporting mods will make or break a combo. Thats why i have seen cam only F13's pull 37x rwhp all the way up to 420rwhp. Now I do think my car can do an honest 440rwhp through the 10 bolt...or very close. After that I forsee some variation of LS6 castings making there way on there with a graph to soon follow.
Old Dec 31, 2007 | 09:03 AM
  #18
SStrokerAce's Avatar
I should have clarified that was STOCK LS1 heads. The 243's are gonna be worth a good 10-20rwhp+ easy.
Old Dec 31, 2007 | 01:46 PM
  #19
IRONFIST's Avatar
If those are your only two choices to look at, yeah the LSA is closer to what works at 112 and the duration is getting in the right ball park. For a shelf cam that has been around for a while that is one of the FEW good ones.
Bret
Well they are my only two choices, because they are so talked about on this board ( I did a little research ). Any other suggestions would be cool too.
Looks like I'm leaning toward the F 13 for both cars, or maybe the F 14 for the WS6 and the 13 for the SS.
Old Jan 1, 2008 | 03:47 AM
  #20
robb4964's Avatar
My LS1 had a 224/228 581/588 114 comp cam and OMG it was like the magic number
It trapped 120 on a few 11 second runs and average 118mph on a full weight 99 ta M6.
Driveability was good and it still sounded pretty mean.
rednekrocketeer
Apr 20, 2015 09:17 AM
94Z28LS1toLT1
Feb 26, 2015 07:47 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
91 Redd Sledd
Jul 28, 2002 12:59 AM
