Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
World Products Heads???
Old Jul 27, 2002 | 12:45 AM
91 Redd Sledd's Avatar
Cool World Products Heads???
Is anybody framiliar with the world products heads??? I have a chance to buy a set of S/R Torquer 305 heads for $200 with about 30,000 miles on them.They are supposed to have swirl polished Manley valves in them.What are they worth?? What kind of gains will I see from these heads??The guy selling them said he picked up a full second by bolting them on.I think that is a little far fetched.What do you all think??My sig has all my mods in it so far. I was thinking the heads and a new cam would wake up the lil' 305.Let me know Thanks!!!!!
James
91 Z-28 305 H.O. 210 RWHP
crane hi-6,holley reg,air foil,3:73 richmonds,Ed Wright stage 2 chip,msd wires,SLP headers,best e.t 14.4@99.02mph
95 S-10 Blazer 4.3l A4 W/230,000 original miles.Never been touched but getting tired.Still likes to do burnouts!!!!
Old Jul 27, 2002 | 12:49 AM
AutoRoc's Avatar
Talking
I say swap the Blazer 4.3 into the Camaro and dump the 305 into the blazer... GM makes some wicked stuff for those 4.3s!
Old Jul 27, 2002 | 12:56 AM
Post
Thanks for the input Denny. But keep in mind I want the Camaro to run and as much trouble as the Blazer is giving me thats probably not the best idea for now.If you check out this months Chevy High Performance they built a 4.3 putting out 300HP and they say it's mild....That one I would swap into the Camaro.
Old Jul 27, 2002 | 01:04 AM
IROC5.7TPI's Avatar
Post
James,
S/R stands for Stock Replacement. These heads have some bowl work done to them and better springs installed, but otherwise you're just getting a set of replacement heads.
If you don't plan on any other mods when you swap the heads, the heads alone should be worth maybe 25HP. If you can find a nice cam to match and a set of roller rockers then you'd be in business.
For $200 i'm sure you can't go wrong unless they're cracked or something.
Mike L.
1987 IROC Z 5.7 TPI A4 3.27 Borg-Warner four wheel disc
Mods:
2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, 3" Flowmaster 3 chamber single outlet, custom adjustable cutout, 3" MAC mandrel intermediate, airfoil, ported plenum. !smog, Crane AFPR, Accel rail mounted FP gauge, Harlan shiftlite, 24lb. injectors, Hedman headers, a few others I forgot...??? FINALLY GOT PAINT!!
Check out my IROC webpage!
Old Jul 27, 2002 | 05:00 AM
Chris Ja's Avatar
Eternal Member
Post
I had a set of dart heads and a crane compucam, tes headers and slp runners years ago and ran 14.0 ets. I wanted more and did a 350. I sold everything but the cam. I still have it in the garage. I think it has about 6000 miles on it. $100.00 bucks if you want it. I think it was like 455/465 lift. Like the old LT1 cams.
14.4 is strong for a 305. I don't think you will pick up 1.0 with the heads and cam. The heads and cam are a better combo than stock tho.
87 IROC L98 700R4 A few mods. Best et 12.96 at 110 mph
All motor No NOS or Supercharger.
96 WS6 FORMULA Best et 13.5 at 105 mph
Old Jul 28, 2002 | 12:59 AM
Cool
The heads are on the guys car so they are in working order.I talked to him more about it today at work.He said he picked them up for about $525 new and had the manley stainless steel swirl polished valves installed.They have about 30,000 miles on them.So I pretty much consider them mine when he gets them off the car.I am going to do a cam also when I do the heads I need to do some reserach to find out what is the best on for my application.So if you all have any suggestions send them my way.It is mostly a street car that does get an occasional flogging at Stanton.After the heads and cam.I am plannig on a stall and some smaller longtubes.Cris Ja shoot me some e-mail about the cam with some specs and stuff and we will talk.Thanks for your input guys.
James
ChrisFrez
Mar 1, 2015 01:33 PM
ChrisFrez
Feb 22, 2015 08:47 AM
NewsBot
Feb 6, 2015 05:00 PM
Dec 1, 2014 08:08 AM
JordonMusser
Sep 11, 2002 12:12 AM
