Cam Bearing in the oil pan ???
Hello Folks,
I have a 150k LS1 that I have enjoyed since day 1, after changing the oil though today I found what I think are part of the cam bearings attached to the drain plug... Can someone confirm that these are parts of the cam bearing. Is it time for a rebuild
There's a TSB on this if you want to read it, was posted in this thread: http://64.65.63.61/forums/showthread.php?t=141496
