cam
Old Jan 8, 2006 | 08:41 AM
assassinls1's Avatar
cam
I have aset of stage 3 ls1 heads and they where milled .30 thousands ls6 intake p tb and full bolt on and n2o. what cam would you run to get the most out of my ls1 thanks?
Old Jan 8, 2006 | 12:56 PM
teke184's Avatar
Re: cam
stage 3 heads.....exactly what does that mean??
every company has different levels that they call 1, 2 or 3.
assuming they flow well any cam will work well with them, however the fact that they are milled could cause problems. you have to watch out for piston to valve clearance with high lift cams.
someone else can probably give you a better idea of a max lift with the milled heads, but i would look for something under .600" lift.
what do you want for hp? 400hp? 450? a good cam with N20? natural?
more info is needed
Old Jan 9, 2006 | 09:02 AM
Kraest's Avatar
Retired
Re: cam
I'd get a FAST 90/90 to replace the LS6 intake manifold if you're looking for even more power. Is this going into a stock displacement 346? You're going to want a cam somewhere in the 23x/23x range for good driveability or 24x/24x range for a more race-orientated motor. I'd call Futral Motorsports to see what they recommend because with milled heads, you have to worry about PtV clearance, like teke said. I'd worry more about PtV clearance with duration and overlap more than about lift, though.
Mike
Old Jan 9, 2006 | 02:40 PM
Greed4Speed's Avatar
Re: cam
Maybe a stage 3 cam to go with those stage 3 heads??? lol
"Stage X" is the modern equivalent to the old "race port" or "race cam" crap.
Granted, if you gave a porting companies name with the stage # like GTP or Patriot that would give people a better idea of what they really are.
Old Jan 9, 2006 | 10:48 PM
StudyTime's Avatar
Re: cam
I'd suggest a 3/4 race cam for that particular set of heads.
Ben T.
Old Jan 10, 2006 | 05:56 AM
Nittanymarine's Avatar
Re: cam
G5X3 cam..
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
