Blow Bye? Should i be worried?
Old Jan 21, 2007 | 08:33 AM
CJ Black LS1 Z28 M6's Avatar
Question Blow Bye? Should i be worried?
Well I had the car dynotuned yesterday. Motor has 134k on it.On the wide open throttle runs we noticed the car had a good amount on blow bye. The car still pulled 332hp and 355 ft tq thru a big 3500 stall convertor. Should I be worried?
Old Jan 21, 2007 | 09:40 AM
AL SS590 M6's Avatar
Moderator
How did you notice the blowby?
Old Jan 21, 2007 | 09:52 AM
The big amount of black smoke that came out when the car was floored
Old Jan 21, 2007 | 10:13 AM
myslowcamaro's Avatar
have a leak down test performed if you are worried about it. i did. while i have a few cylinders causing smoke in the high rpm band, it still runs strong, i just wouldnt put nitrous on it.
Old Jan 21, 2007 | 12:25 PM
Kraest's Avatar
Retired
Black smoke = fuel
Bluish-black smoke = oil burning.
Old Jan 21, 2007 | 02:13 PM
Thanks Kraest, It was a decent amount of black smoke. Is this just because of mileage?? The car was running on a **** tune for many months so the a/f ratio was horrible. thnx
Old Jan 21, 2007 | 07:11 PM
Kraest's Avatar
Retired
It just means that it's running rich, probably because of the **** tune you speak of.
Old Jan 23, 2007 | 05:33 PM
Bayer-Z28's Avatar
was it at the higher RPM's or @ 2000~ish when they started the pull? I asked the same question when my car was tuned. The guys @ ESP said it was normal for LS1's to smoke at high RPM's. From what I read over on the other board, it's actually because of the PCV system. A catch can can fix that.
The PCV system on the LS1's pulls the crank case 'vapor' form the valve cover. On the LS6's it pulls from the cam/lifter valley. -Less chance of sucking oil that way.
My smoke seemed grey.
Old Jan 23, 2007 | 05:47 PM
Higher RPM's. Thanks alot. I guess its just build up due the high mileage. The car has 134k on it. I was worried because my old 99 Z28 at 44k didn't blow out smoke like that and my SS didn't on the dyno either
Old Jan 23, 2007 | 05:52 PM
Bayer-Z28's Avatar
Replace the PCV valve. Might be the culprit.
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
