bent pushrod on #4 cyl
Old Mar 8, 2012 | 07:34 AM
treyville's Avatar
Is this as easy as some say,
I'm just changing the one, do i have to rotate the engine to adjust values? if that make any sense...
Old Mar 8, 2012 | 09:35 AM
greenformula94's Avatar
Re: bent pushrod on #4 cyl
All you do is take off the roller rocker.
Remove old pushrod. Inspect and figure out why it bent.
fix issue accordingly.
Replace pushrod and roller rocker. tighten the poly lock up a little
Then start the motor and tighten the poly lock til the rocker is set.
Old Mar 8, 2012 | 12:05 PM
treyville's Avatar
thanks, install the valve cover & coils then start engine to set roller rockers if clacking?
Old Mar 8, 2012 | 01:57 PM
well if you if your going to set the preset of the rocker while running then you gotta do it with the valve cover off. you can set them with the motor off too, and thats when you gotta rotate the motor n what not like you were referring to
Old Mar 13, 2012 | 07:49 AM
Marc 85Z28's Avatar
Poly locks? Silly LT1 guys
Remove the valve cover. Remove the rocker arm. Replace the pushrod. Install rocker arm, torque bolt to 22lb/ft (this additional step is not necessary, but feel free to rotate engine over 1 turn, and retorque rocker arm). This valvetrain is not adjustable, so there is no preload to set, or locks to deal with. Reinstall valve cover. Start it up and hope you didn't bend the valve. Then, learn how to drive better
Old Mar 15, 2012 | 12:30 AM
rod442's Avatar
Curious, how do you know you only bent one?
Old Mar 15, 2012 | 01:30 AM
Lol when I made that post I didn't read it was a lsx lol
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
CARiD
Sep 30, 2015 05:44 AM
cmsmith
Sep 14, 2015 09:09 PM
94Form
Jul 17, 2015 10:56 PM
