is the bbk 80mm throttle body worth it?
Old Sep 22, 2003 | 11:18 AM
MistaCamawo's Avatar
My car came with a functional ram-air hood, k&n, Z06 MAF, and flowmasters. Do you think I would benefit from an 80mm throttle body? Also, how much power can be gained from a good set of headers? An add says 30 hp, but I'm skeptical that it will be that much.
Old Sep 22, 2003 | 02:18 PM
teke184's Avatar
a larger throttle body would probably gain you about 5hp...hardly worth the $300 price tag
and a good set of longtubes, through a standard catback will gain you a solid 15hp...it has been dynoed several times by guys in the past few months.
i think Jason D (admin) installed Jet-Hot lt's on his 02 Z28 and dynoed like 16hp gain peak.
that isn't to say there isn't more of a gain elsewhere in the curve, which is just as important as peak.
Old Sep 22, 2003 | 03:18 PM
GrdLockV6's Avatar
Unless you've got a decent lift cam and a nice set of heads, or some forced induction, etc, a larger throttle body is a waste of money.
Old Sep 22, 2003 | 03:30 PM
95GRNZ's Avatar
Thumbs up
Yup.
Not worth the $$$ without bigger mods.
TS
Old Sep 22, 2003 | 03:45 PM
foff667's Avatar
just port out your stock one...most run stockers even into the 400+ hp range so i think the 300 can go to something else
lata
Bill
Old Sep 23, 2003 | 09:03 AM
iateyour5.0's Avatar
I've got this tb, and I couldn't really tell that much of a difference until I put on my Cat-back exhaust. Then, with those two combined, it was a pretty big difference.
Peytons'z
May 6, 2021 09:25 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
lt1-xjs
Jan 17, 2015 07:52 PM
