Bassani y-pipe
Old Aug 26, 2007 | 06:18 PM
MeanZ687's Avatar
Bassani y-pipe
I was planning on getting a bassani y-pipe for my 99 SS but keeping the stock manifolds and i already have magnaflow catback already. Is this a good choice or are there any others you guys recomend?
Old Aug 26, 2007 | 06:39 PM
Need4Camaro's Avatar
I honestly think longtube headers will yield more than the Y-Pipe but of course, the combo together would be for the best results
Old Aug 26, 2007 | 09:09 PM
Kraest's Avatar
Retired
LT headers are worth a ton of power -- around 20rwhp/20rwtq on an LS1 engine.
Also, those are necessary if you're doing any internal mods.
Old Aug 26, 2007 | 09:24 PM
pitbull14218's Avatar
i would like to do Headers but i dont want to not have the cats. They do make Headers with cats they are expensive right?
Old Aug 26, 2007 | 10:15 PM
Kraest's Avatar
Retired
I think they are a couple hundred dollars more for the high-flow cats.
There's no reason to keep cats unless you have emissions testing and they visually check for them.
Old Aug 27, 2007 | 06:46 AM
AL SS590 M6's Avatar
Moderator
The 98-99 f-body manifolds suck. Changing the y-pipe will net tiny gains in comparison to the money spent.
Old Aug 27, 2007 | 08:45 AM
teke184's Avatar
i installed the bassani Ypipe on my 99 when i first got it.
in all honesty...for the $$ and the hassle of the install (didn't fit very well) it was NOT worth it at all.
i had it installed with a catback at the same time...and felt minimal gains.
not to mention there was a ton of clearance issues with the frame.
bottom line
money better spent elsewhere!!!
Old Aug 27, 2007 | 10:22 AM
Also I thought the cats were on the Y-Pipe, not the headers... unless 98's and 99's are different I think you'll have to change the cats if you change the Y-Pipe OR Headers because the cat's connect them together...
Old Aug 28, 2007 | 07:36 AM
teke184's Avatar
the bassani ypipe that i had replaced the cats. it had flanges that bolted directly to the manifolds.
the driverside cat is bolted to the manifold, the passenger side is mounted farther back.
pics of my bassani:
installed showing clearance issues:
close up:
Old Sep 1, 2007 | 01:29 AM
MeanZ687's Avatar
Were you happy with the bassani y-pipe and how more lower is the ground clearence?
Old Sep 1, 2007 | 04:32 AM
Moderator
I bought a Bassani OR Y-pipe in 2001 that was great, fit, finish, clearance were all good.
Quickss96
Jan 29, 2016 05:56 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Noer
Parts Wanted
May 4, 2015 04:58 PM
smokin stangs
Aug 3, 2002 11:08 PM
smokin stangs
Jul 31, 2002 06:23 AM
