Bassani Headers
Old May 26, 2004 | 11:08 PM
SamsAm346's Avatar
Bassani Headers
I was wondering if anyone has experiance with the Bassani headers for the LS1. How load are they? Performance increases, etc. I am intending on getting the y with the high-flow cats and a SLP loudmouth cat back.
Old May 26, 2004 | 11:18 PM
SSpdDmon's Avatar
They're a mid-length header (as far as I know). Gains will be better than shorties, but long tubes (like SLP, QTP, FTP, Hooker and Pacesetter) will tend to get you greater gains.
Old May 26, 2004 | 11:55 PM
99blackSS's Avatar
I have MAC headers, which are also mid lengths. I got them because the gains are supposed to be almost as good as long tubes but with better clearance and shorties are a waste. Bassani headers look like the same design as the MAC headers. On the stock SS cat back the MAC system (with cats) sounds slightly louder then before. It mainly changed the tone, sounds really good at around 2500 RPM.
Old May 27, 2004 | 01:43 PM
teke184's Avatar
i had the bassani off road Ypipe and the quality was top notch. fit was a bit off, but nothing horrible.
i think you'd be happy with the headers. they are very well known in the mustang circle
Old May 27, 2004 | 07:10 PM
Gloveperson's Avatar
Yea I have a friend with a 5.0 with Bassani headers. Great qualitity.
Although, I wouldn't get the SLP Loudmouth with headers. The drone might drive you crazy. I recomend Magnaflow, which sounds great!
www.ls1sounds.com
go there to see what you think of the loudmouth and headers.
Old May 30, 2004 | 03:07 PM
mrr23's Avatar
i did R&D on those headers along with the y-pipe and hi-flow cats for them through www.vincihighperrformance.com they needed a car as close to stock as possible. all mine had at the time was a borla catback with the medium plate. this is the results of just the headers and y-pipe with cats. no tuning.
what the dyno doesn't show is under 3000 rpm driveability. in auto eqipeed ls1s, the motor doesn't start pulling very well until about 3200 rpm. the headers brought that 'pull' to about 2600 rpm.
install on headers
dyno results
and no there wasn't a loss of peak torque. there is a spike on the before run at the beginning of the run. look at the whole graph. a gain all the way across the board.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
