FAST LSX questions
Old May 25, 2004 | 10:29 AM
camaronewbiess's Avatar
FAST LSX questions
Hi, I was looking at buying a LSX intake manifold...they make some pretty large HP and torque claims. My car has a lid and long tube headers, do you need a head and cam or something powerful to see a big result with the LSX, or would it give me substantial gains with what i have? Also, do you need the matching FAST Throttlebody or will the 78mm lsx fit the stock throttle body? Thanks for the help.
Old May 25, 2004 | 10:42 AM
blazers's Avatar
If you are not doing any serious stuff to the engine, an LS6 intake will be the best bet.
Old May 25, 2004 | 11:15 AM
Why is that, Because the LSX would be overkill?? Would it be worth it to even get a LS6 intake ...or just leave stock?
Old May 25, 2004 | 11:48 AM
blazers's Avatar
If you have an 01-02 LS1 it already has the LS6 intake. It depends on what hp you are looking for. The LS6 intake is good for anything up to about 450 rwhp. If you are not going over that, don't waste your money on the LSX.
Old May 25, 2004 | 11:59 AM
stone4779's Avatar
hey blaze:
are those the only mods you have to get that 375 rwhp?
Old May 25, 2004 | 12:06 PM
blazers's Avatar
Originally posted by stone4779
hey blaze:
I also have a mild street cam. 224/228/114 0.578 lift.
Old May 25, 2004 | 12:09 PM
stone4779's Avatar
if you could go 112 LSA would you now that youve driven the 114 for a while? Not much difference?
Old May 25, 2004 | 06:05 PM
dmnall's Avatar
Look at the latest Chevy Hi Performance Magazine. I read the article about the different LS1/LS6 Intakes and the worst was the Lingenfelter/Weiand intake, 6.0 Truck Intake was the best performing eventhough not by much like 4 hp more then th LS6. The LSX intake was around 1 hp more then the LS6 and 3 hp less then 6.0 Truck Intake. My money would still be on the LS6 intake since the 6.0 Truck Intake looks like there might be clearance problems with our cars and for the price LS6 runs around $ 300 versus the LSX which is $ 780 + and is 1 HP worth almost $ 500 more? Not worth it in my opinion... Note the tests Chevy Hi Performance Mag ran were stock displacement with the exception of the Cam.
Charlie
Old May 25, 2004 | 06:13 PM
stone4779's Avatar
wow, i would've thought it was more than that
My money would be on an LS6 intake
ive seen'em on ebay for under $300 shipped, you just have to be patient and bid on low priced ones and hope nobody else outbids you. Just be careful, ask a lot of questions, check the part #'s and make sure it either came off a 2000+ Camaro or a Z06
Old May 25, 2004 | 06:25 PM
Pewter Z's Avatar
I am assuming you are talking about one of these on eBay . My question would be what else would you need to buy to bolt that on or is it a direct bolt on replacement?
Old May 26, 2004 | 12:47 AM
stone4779's Avatar
Im pretty sure none of them have EGR(LS6) so thats one problem
Im not sure about your area but some places make a big deal about it. (inspection stations)
I bought block off plates for my car for the headers and EGR, that is noticable, but since the LS6 dont have it maybe they wont notice.
Old May 26, 2004 | 06:40 AM
teke184's Avatar
you also need coolant bleed tubes and plugs (something like that)
check out the LS1/LS6 section of www.paceparts.com, it's in the induction section...only costs like $40
Old May 26, 2004 | 08:58 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
You will also need to change your throttle body, or at the least get an adapter plate.
Better off to get a cam.
JMHO
SteveC
Old May 26, 2004 | 10:13 AM
stealth2's Avatar
We sent ours back before we installed it because we heard that it will not hold over 10 lbs without the 3 pieces being glued together. We are staying wih the LS6 until we change to sheetmetal.
Old May 27, 2004 | 02:42 PM
1stls1's Avatar
So with the LS6 intake, it is just a swap w/out any mods? It will bolt right up to a stock tb. And just making sure, it was said a intake from a 2000+ camaro or Z6, right?
