B&M shiftplus
Old Apr 26, 2003 | 12:41 PM
WhoBetter?'s Avatar
B&M shiftplus
has anyone tried this $40 unit, is it worth it?
Old Apr 26, 2003 | 01:27 PM
sleeperZragtop's Avatar
It won't work on LS1 cars...otherwise it's a very cool unit...
Old Apr 26, 2003 | 04:14 PM
Bone Maro's Avatar
Yes, it will work on our cars. But, you'll blow up your 4L60E.
In 98, the 4L60E was changed. The front pump went from steel to aluminum, and the Shift+ increases the line pressure quite a bit. Sooner or later, you'll blow the front pump because of the pressure demands.
That's why it will work on earlier 4L60Es, because the steel pump is stronger and can handle the extra line pressure
Old Apr 26, 2003 | 06:51 PM
..a quote from their web site
part # 70380 For GM rear wheel drive and 4wd trans code MT1 or M30 (RPO code found on sticker in glove box) '93-'98 Suburban, Tahoe, Blazer (C/K, S/T), pickup (C&K) 1500, 2500, 3500, Impala, Camaro, Firebird & '94-'98 Corvette.
Old Apr 26, 2003 | 07:24 PM
WhoBetter?'s Avatar
So i guess that 93-98 note includes camaro, that sucks for you guys, but i've got a 3.8L, I only asked you guys because no one in the v6 section wanted to talk about it, but i guess the v6 doesn't matter, i'll have to research this more,
Old Apr 26, 2003 | 07:36 PM
Bone Maro's Avatar
Yes, don't use it on a 98 4L60E.
Go check LS1.com or LS1Tech.com. You'll hear the same response.
Old Apr 26, 2003 | 07:41 PM
WhoBetter?'s Avatar
yeah, just found it on thunder racing, said it doesn't work on 1999+ f-bodies, that sucks.
camarobird92
Nov 30, 2008 07:33 PM
Mikes 1994 z28
Apr 27, 2005 07:39 PM
SlyStoner421
Mar 7, 2005 11:50 PM
shoebox
Sep 4, 2004 05:22 PM
VegasZ
Sep 5, 2003 12:05 PM
