anyone use this cam?230/230 Dur, .592/.592 lift, 110 lsa
That's a nasty cam. I don't have any experience with it..but I'll guess that it would be worth ~ 60 rwhp depending on what kind of heads you are running and peak around 6500 rpm. Probably idle like crap, too.
Go to LS1tech.com and search for the TR230 results.
...I've the the 228R cam and I love it big time...you'll need a tune for sure...as for head work be careful, you may run into valve clearence issue's..and if you do want ported heads, you'll have to go with 5.3 heads..
I have a 230/230 .590/.590 on a 112 with my h/c setup.I dynoed 443/407 on a low dyno. The cam is big and with tuning it can idle decent. I have no track times with my car yet untill I get a 12 bolt. I am shooting for 10's.
