Anyone know how to turn the daytime running lights off?
Old Aug 3, 2003 | 06:23 AM
USHotRod's Avatar
I absolutely cannot stand these things. If anyone were to be so kind as to tell me how to get rid of these, I would really appreciate it.
Old Aug 3, 2003 | 08:29 AM
mvs's Avatar
mvs
There are two modules behind the radio that are mounted against the firewall. Unplug the module to the far right and DRLs go away. You can either remove the radio to access the module or you can lay on the passenger floor and reach back behind the radio to unplug this module.
Be aware that by unplugging this module, you will now need to turn on your lights manually at night and the emergency brake light will no longer illuminate. There is another option, but it requires taking the unplugged module apart and soldering some jumper wires.
Good luck.
Manny
Old Aug 3, 2003 | 09:30 AM
Formula One's Avatar
Pull your parking brake up 1 click before you start your car
Old Aug 3, 2003 | 10:04 AM
Kwiksilverz28's Avatar
Enjoy the added safety. You can't see them while you are driving anyways. I just wish there was an easier way to defeat the auto headlights at night. My Blazer you just push the dome light defeat 4 times in 6 seconds....
Old Aug 3, 2003 | 10:16 AM
USHotRod's Avatar
What will that do exactly???
Old Aug 3, 2003 | 10:30 AM
krillanaross's Avatar
yeah whats up with the automatic headlights, i always wondered if it was supposed to do that. do your tail lights light up too? i guess i could check on my own.
Old Aug 3, 2003 | 10:33 AM
therealmagyver's Avatar
look up ratio411 on cardomain. He has the write up.
Old Aug 3, 2003 | 10:41 AM
2000TA's Avatar
From what I understan by unplugging or pulling your pulling your brake up one you not oly disengage the DDL but your light to your brake will not light up no more or stay lit up ned it disables your airbad due to it thinks you are parked
Old Aug 4, 2003 | 09:24 AM
teke184's Avatar
i have a write up of 3 diffent mods to the headlights on my web page
headlight mod page
the one you are asking for is on the bottom, i have not tried it yet so i can't give tips or pictures...but soon
Old Aug 4, 2003 | 01:33 PM
camaro322hp's Avatar
Good luck.
Manny
yeah, that's the easiest way. that's what i did. the module sits behind and to the right of the stereo. after you pull the stereo, you'll see the module back there, black and about the size of a pack of cigarettes. there are two harnesses plugged into it. you want to unplug the BLUE harness. bingo, that does it... i also liked that it disabled the auto headlights. i don't like it when the car tries to think for me... also like to be able to go into stealth mode at night...
squarehead
Jan 15, 2015 07:02 PM
97z28k&N
Jan 9, 2015 04:58 AM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
