Any truth about series I and series II
Old Jan 4, 2004 | 02:14 AM
tylerdurden's Avatar
Question Any truth about series I and series II
Iam planning on buying a 98' t/a 72,367 miles for 12,000; from a used dealer in my area. My question is, if a aftermarket ls-6 intake is used(which does not have the egr provision) is it possible to remove the egr equipment and put in a newer ecm, from egr deleted years 01'/02'. I have heard that there is something about a series I data link 98'- 00'; and then a series II on the 01'/02'; and the two are not compataible even though they look the same; its about how the info is transfered back and forth.
Should I wait and get a newer model 01 ram air for 18,800.
Old Jan 4, 2004 | 12:27 PM
Beast96Z's Avatar
Not sure about the ecm, but if you buy a 98, and you ever want to put heads on it, you will be stuck with perimeter style valve covers which will not allow you to upgrade to LS-6 without buying new covers. Some people don't even keep perimeters in stock, you have to send them yours to be ported. I'd at least get a 99, but the best would be 01-02.
Old Jan 4, 2004 | 12:57 PM
LeadSled1's Avatar
I believe it is patriot performance that has an overstock of 98 perimeter heads and is selling them ported stage II for $995 with no core. There was a thread on LS1Tech.com about it in the internal engine section. Buy it and get these heads!
http://www.ls1tech.com/forums/showth...riot+perimeter
Look at the 8th post down by Terry Wilkes. He is the guy from Patriot.
Jess
Old Jan 4, 2004 | 03:46 PM
So I guess the 98 99s are GMs red headed step childeren years. I thought all ls motors were center style holds, but never viewed an engine compartment from a 98-99 up closely, thanks for the heads up on future problems that could be costly.
Old Jan 4, 2004 | 05:45 PM
LeadSled1's Avatar
98s only.
Old Jan 5, 2004 | 12:00 AM
Gold Z's Avatar
It's no big deal to change 98 heads over to the 99 and up center bolt style. Buy a pair of used center bolt valve covers and a new coil mounting brackets and you're ready to go. Not a big deal. That's why you can buy the perimeter bolt heads so cheap....people are buying the center bolt heads for their 98s.
Old Jan 5, 2004 | 12:22 AM
What about the ecm from a newer model which does not have the egr provisions, can that be used; if the egr system is removed?
Old Jan 5, 2004 | 12:39 AM
Gold Z's Avatar
EGR can be deleted with LS1 Edit. My son deleted EGR on his 99 Z28 and is using a LS6 intake on it now. You can do the same on a 98.You can't switch computers from a 98 into any other year because the programing language is different but why would you ever want to?
Old Jan 5, 2004 | 01:56 AM
Because I did not know that you could delete the egr part out of the computer system. After all, whats the whole point of up grading a 98 system to a ls6 system; heads and aftermarket intake if the only thing that is stoping you is an egr system, that can not work on the ls6 system.
Quickss96
Jan 29, 2016 05:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Catmaigne
Jul 14, 2015 05:17 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
BamaZ28
Aug 22, 2002 04:47 PM
