Another LCA question
Old Aug 11, 2003 | 03:56 PM
96Z28man's Avatar
The car has been running like a truck since, at least in the back, it is really rough, every little bump is noticable. I've heard this is normal, so is there a way to fix it? will new shocks or anything like that help?
Old Aug 11, 2003 | 07:40 PM
foff667's Avatar
Re: Another LCA question
go back to the stockers with some rubber bushings ...its perfectly normal when you go to poly or rod ended lca's to be stiffer not much that i know of you can do other then go back to stock...but you put them on to make your car handle and launch better not so your ride is like a caddy.
lata
Bill
lbrowne
Nov 13, 2011 04:25 PM
Brad 97z
Aug 10, 2002 09:58 AM
Trevor98ramair
Jul 31, 2002 02:43 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
