another Hypertch PP3 question?
Hey guys,
My damn SES light came on and I have no idea why.
Anyway, I have tuned it with my Hypertech PP.
Do I have to return it back to stock programming if I want to run a diagnostics check?
I don't have an warranty on the car, just in case you are wondering.
Anyway, I have tuned it with my Hypertech PP. Do I have to return it back to stock programming if I want to run a diagnostics check?
I don't think my SES is related to me using the HPP. I've had it for a few weeks now with no problem. I just drove back from out of town. (around 350 miles round trip)
But I want to know if I need to return it back to stock programming for a diagnostics check?
I'll go ahead and check my fuses, everything seems to be working fine though.
Read their manual - they mention that the dealerships (anybody's really) diagnostic equipment is geared to look for stock programming.
The HPP3 Power Programming could cause some diagnostic issues , and given how easy it is to remove & install - why take the chance ?
That's how I do it w/ my car.
Later !
Britt
Later !
Britt
If you're just running AutoTap or getting AutoZone to scan the codes for you, there's no need to remove the HPP tuning.
However, if you take it to the dealer ... for ANY reason ... remove the HPP tuning. Even if you take it in for an oil change, most dealers scan the codes real quick to ensure there is nothing else wrong. (At least the dealers in Memphis). If the scan tool doesn't recognize the tuning, which it won't if you have HPP tuning installed, then they will reflash the PCM with the latest update. If that happens, you will have to get Hypertech to unlock your programmer, and they will only do that if you are the original owner of the tuner.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
