Air/Fuel ratio gauge ?...
Old Feb 10, 2003 | 05:38 PM
Michael Ozorowsky's Avatar
Question Air/Fuel ratio gauge ?...
Anyone know where I can get an adapter for an autometer a/f gauge, so I dont have to splice any wires? I know there is something out there that I can just plug into, but don't know where to get it, thanks in advance.
Old Feb 10, 2003 | 06:04 PM
stik6shift98's Avatar
i think either
www.thunderracing.com
www.tbyrne.com
or www.jegs.com
will have it
Old Feb 12, 2003 | 05:47 PM
Hey, where do I find the wire I splice into to hook up the gauge? Any tips? Thanks.
Old Feb 12, 2003 | 06:08 PM
i thought u didnt wanna splice.....
its where u conect the o2 sensor in....i think to the black wire....maybe its white......ill have to double check
Old Feb 14, 2003 | 10:54 AM
RdRacerZ28's Avatar
Then you can tell if you're running yellow,green or red!!!!!!
Old Feb 14, 2003 | 11:14 AM
or stoich rich and lean
Old Feb 14, 2003 | 11:18 AM
RdRacerZ28's Avatar
it will never stay in the green..should bounce between rich and lean averaging 14.7:1. @ Wot you'll want about 13-13.2:1. If it was rich you'd know without a LED and if it was lean you'd know as well. The factory sensor is slow. Thats why you need a high-speed wide band sensor to get some good readings. The gauges look kinda cool, but in MY opinion they really arent going to give you any useful info.
Old Feb 14, 2003 | 08:59 PM
Where did you splice the power lead from? The only wire I know the location of that only gets power when the car is on is the one to my asr. Right now, I have my electric cutout spliced off that. Will it be ok to splice my a/f gauge off that, or you know a better place? Thanks again guys.
Old Feb 16, 2003 | 05:44 AM
Ghost SS's Avatar
Return the gauge and get your money back....it is a dummy gauge. It is very innaccurate and just a waste of money. Just wire up a DVM to your o2 sensor. It is the only way to get true readings.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Campbellb48
Jul 5, 2015 06:31 PM
97ss1826
Mar 13, 2003 11:58 AM
91Bird305
Aug 25, 2002 06:56 PM
