Ahh help with wheel hop
Old Dec 23, 2003 | 07:14 PM
X-Roush Stanger's Avatar
Ok guys I needs your help. Just the other day I got 18s all around (got a really good deal that I couldn't pass up) with 274/35 tires. Now I floored it on dry ground I have wheel hop. I need to fix this. What can I do? I'm starting to think that the tire place I took the wheels to put too much air in the tires. I don't know if this could effect it. I am going to check that right now. Also it seems to happen on the passenger side, if that makes a difference.
Old Dec 23, 2003 | 07:19 PM
psychocabbage's Avatar
LCA's, Panhard rod, and Torque Arm.. or a Torque Arm bushing (Like Energy Suspension), and 1 Air Lift Air bag in your right rear spring set to 21psi.. that should cure your wheel hop.
It did mine on my other car.
Old Dec 23, 2003 | 07:31 PM
damn I didn't know switching to 18s would cause wheel hop. I just went from 275/40 to 275/35.
Old Dec 23, 2003 | 08:11 PM
My84Z's Avatar
wheelhop is common on these cars your old setup probably did it just not as noticeably. a good way to fix it is some nice lca's and if your car is lowered or will be lowered some lca relocation brackets.
Old Dec 23, 2003 | 08:36 PM
cerealtool228's Avatar
ehhh .. bushing didnt help me one bit ...
Old Dec 23, 2003 | 11:28 PM
JaysGone's Avatar
Just stick your head under the rear of the car. If your LCAs arent parallel to the ground get a set of relocation brackets. BMRs bolton works fine. If your on a budget use the stock arms. No real need for all the other crap Oh and get a BFH for the wheel rubs you will need it
Old Dec 23, 2003 | 11:36 PM
DarkblueTA's Avatar
All I did was put Lakewood LCAs on with Poly bushings....did the job for me.
Old Dec 24, 2003 | 01:31 PM
Thanks guys for the help. So it looks like if I were to do it in order I'd get lca's first and then a torque arm.
Old Dec 24, 2003 | 01:36 PM
makes no sense to not get the whole deal and have a decent setup and get some benefit from the car... Handling and acceleration. That is what your intent is isnt it?
Old Dec 25, 2003 | 04:22 PM
I'm just saying since I don't have all the money to buy it all at once I want to get the piece that will most benefit me the most first.
Old Dec 25, 2003 | 04:24 PM
RS Dragster's Avatar
Best thing first is a new set of LCA's. Might as well do reloc. brackets at the same time (they're only $45).
Good luck and keep us posted.
force10
Aug 10, 2015 08:30 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
SAR2K
Sep 1, 2002 10:49 AM
wytblur
Aug 5, 2002 02:03 PM
