AFR Heads w/ CC 224 cam 500+ hp?
Old Jun 14, 2004 | 07:38 PM
Zerocool's Avatar
in this magazine here at my work they claim 500+hp from the new AFR 2.02/1.60 heads with a comp cam 224 duration camshaft ONLY. is this possible to do a heads and cam swap on a stock motor and get these kind of gains? i would think u need more then this for that kinda gain, such as a lid and full exhasut with headers etc. plus a tune and so forth... And is this set up smog legal?????
thanks
Old Jun 14, 2004 | 08:59 PM
SSpdDmon's Avatar
I was just reading the description on their website (www.airflowresearch.com) and I'm pretty sure they mean flywheel horsepower. They were using an '01 SS as a base, so it already had an LS6 intake and I'd bet money it had headers too.
Old Jun 14, 2004 | 09:29 PM
MISOMWS6's Avatar
I hope they were talking about fwhp.....even then it seems a bit steep....
Old Jun 15, 2004 | 12:49 AM
david97gsxr's Avatar
well, considering the stock heads they dyno tested, dynoed at 428 hp, i'm assuming it's flywheel horsepower. and if you look further down, the corrected hp number is more like 450
http://www.airflowresearch.com/dyno/ls1_030804.htm
oh, and corrected, their stock heads dynoed at just over 400.
Old Jun 15, 2004 | 02:39 AM
Zerocool's Avatar
hmm so is that setup in the magazine smog legal???? with the 224 comp cam?
Old Jun 16, 2004 | 08:09 PM
Beast96Z's Avatar
The comp 224 can pass smog if cut on a 114 and a good tune. These guys are deffinatlly talking FWHP. LG motorsports did a test with their G5X-3 cam and these heads which netted 470-480 RWHP. They should be good heads, but I'd wait till a few more real world tests have been done/
Old Jun 23, 2004 | 05:35 AM
dist0rtion_69's Avatar
Read up on ls1tech.com. These are rwhp number, according to an employee of AFR. The heads also made 409rwhp on a z06 with the only other mods being like a catback or something. I forget the specifics, but it made 409rwhp with stock cam, manifolds, etc.
Downright insane, if you ask me. But then again, I made 428rwhp with stock heads through a 12 bolt.. Wonder what I'd make with my pistons flycut and some AFRS !!!!
Josh
Old Jun 23, 2004 | 12:06 PM
uhm, i thought zo6s made 405 flywheel horsepower stock? and you know how GM under-rates their engines, and even if that is correct, 15 percent drivetrain loss is ~340 rwhp, which would mean these heads + a catback yeilded a gain of 69 horsepower.
however, it would also mean a zo6 only makes 30-35 more horsepower than a LS1 camaro.
eitherway, a link to this thread would be nice.
Old Jun 23, 2004 | 02:01 PM
http://www.ls1tech.com/forums/showthread.php?t=183782
http://www.ls1tech.com/forums/showthread.php?t=183758
Highlander
Jan 12, 2020 02:13 PM
parkers Z28
Mar 11, 2016 08:14 PM
MadMav
Feb 6, 2015 11:02 PM
Highlander
Aug 9, 2002 02:30 AM
super83Z
Jul 11, 2002 10:16 PM
