99 T/A trouble
99 T/A trouble
well, i just started to notice a problem with my car and i cant figure it out. when i am accelerating, on the driver side of the engine, there is a decently loud ticking that i have noticed. i was thinking it could be a damaged hose somewhere or EGR related. the car also seems to be down on power..... any ideas on what this could be? it seems like if it isint one thing, than its the other for me
Nick
Nick
Re: 99 T/A trouble
he means the bolts holding the manifolds to the head....there could be a leak.
is it a "pfft" sound or a tick?
"pfft" would be an exhaust leak
does it coincide with increase in rpm? could be lifter tap, a bad lifter or a broke spring, bent pushrod
has it been over reved recently?
Re: 99 T/A trouble
thanks
Nick
Re: 99 T/A trouble
i'd put money on a bent pushrod, they are well known to give out after over reving.
could also be a bad lifter or bent valve i suppose
pull the valve covers, pull the pushrods and roll them on something flat, see if you can find the bent one...
it may be obvious to the nakid eye...maybe not
Re: 99 T/A trouble
unbolt the rocker arms too...
but yeah..it's pretty simple.
i mean even reinstalling the rockers is cake...just put them on, and torque the bolts to 21# ...or maybe it was 23# not sure off hand
no setting valve lash or anything.
