99 ls1 I forgot what I read but somthing about a master/slave cylinder update/mod?
Old 02-07-2004, 01:37 PM
BLACK Z !'s Avatar
What is th emod that I read a long time ago in a mag about upgrading the clutch system on the certain 4 th gen cars?
BLACK Z ! is offline
Old 02-07-2004, 03:06 PM
CrippleFightin's Avatar
Its a recall for the 99 z28 m6's.
CrippleFightin is offline
Old 02-07-2004, 08:44 PM
S84Z28's Avatar
Later models changed to an improved slave cylinder setup
S84Z28 is offline
Old 02-08-2004, 02:00 AM
Beefcake61's Avatar
Where did you happen you hear that from, I'm looking at getting a spec clutch, and they recommend an upgrade on those items there.
Rob
Beefcake61 is offline
Old 02-08-2004, 02:04 AM
99blackSS's Avatar
Campaign Number: 99V239000 Date: 1999-Aug-30
Component: Power Train: Clutch Assembly
Defect Summary: VEHICLE DESCRIPTION: PASSENGER VEHICLES EQUIPPED WITH MANUAL TRANSMISSIONS. THE CLUTCH MASTER CYLINDER MAY HAVE BEEN BUILT WITH AN INCORRECT RETAINING RING.
Consequence Summary: THIS MAY NOT ALLOW THE CLUTCH SYSTEM TO DISENGAGE THE CLUTCH WHEN THE CLUTCH PEDAL IS DEPRESSED, RESULTING IN UNINTENTIONAL VEHICLE MOVEMENT, INCREASED STOPPING DISTANCES, ENGINE STALLS, AND DIFFICULTY IN SHIFTING.
Corrective Summary: DEALERS WILL REPLACE THE HYDRAULIC CLUTCH MASTER CYLINDER WITH A NEW CYLINDER.
99blackSS is offline
10-31-2016 11:09 AM
lt1matt
03-21-2015 07:35 PM
HectorM52
03-15-2015 10:45 PM
jayblev95
Track Kill Stories
01-15-2015 07:48 AM
z28projects4ever
9
07-16-2002 07:48 PM
Quick Reply: 99 ls1 I forgot what I read but somthing about a master/slave cylinder update/mod?
