98' to 00' What Are Most Common Problems?
Old Aug 3, 2003 | 10:11 AM
Racer-X's Avatar
Question 98' to 00' What Are Most Common Problems?
I'm going to be looking for a M6 LS1.
My brother had a 99' M6 with few mods for five years and no problems.
I just want to know if that was a fluke or if their that good.
His stock clutch lasted till he sold it and he would race it.
My LT1 with high performance clutch lasted only two years.
Thanks,
Jim
Old Aug 3, 2003 | 10:45 AM
2000TA's Avatar
breaks and rear end that is all i know about no other probs here
Old Aug 3, 2003 | 03:07 PM
mr_muff's Avatar
clutch
they suck, i have 50,000 KM on my car (about 30000m, i think) and i have never been hard on it and it is on its way out. that and i find a lot different than my buddies old 95 Z, the old ones i think were much better.
Old Aug 3, 2003 | 03:13 PM
Hyperspeed97z28's Avatar
didnt 98's have alot of piston slap at startup ??? oil consumption??
Old Aug 3, 2003 | 04:00 PM
KamaroL98's Avatar
Uh, not mine and i drive mine hard. I just take care of it i guess..
I did break my rear end like 3 days ago, but thats becaus im pushing well over 400rwhp and used slicks a few times at the track, and street. Then i ride around around on drag radials on a regular basis. So, ya know... The GM 10 bolt is pathetic.. I just ordered a Moser 12 bolt so its all good. I dont see how some of these guys with basicially stock cars are get piston slap or oil consuption, they must drive them like idiots.
Old Aug 3, 2003 | 04:08 PM
ULTIMTEORANGESS's Avatar
weak rears when raced and warped rotors.
Old Aug 3, 2003 | 10:01 PM
mr_muff's Avatar
it isn't the driving that does it. my car has consumed oil since i bought it and piston slap comes from the factory. both of them are not really related to driving. well not when they are brand new and doing it it isn't driving.
Old Aug 3, 2003 | 10:06 PM
SLOW_SS
Guest
Posts: n/a
I have 2000 SS, no problems yet. Still have stock clutch and rearend. I have 4.10 gears and I'm some what surprised that rearend is still holding up.
Old Aug 3, 2003 | 11:06 PM
mcflyz28's Avatar
power window motors.
Old Aug 3, 2003 | 11:45 PM
AL SS590 M6's Avatar
Moderator
Nope our 98 is as quiet as a mouse.
Now the 00 has the piston slap until warm.
Old Aug 4, 2003 | 01:17 AM
camaro322hp's Avatar
my adventures:
power window motors
coolant level sensor
ABS module
leaking t-tops
IMO not bad for 65k miles. it was all covered under warranty. i've used about 1 qt oil per 3000 miles since new.
Old Aug 4, 2003 | 05:10 AM
Black98's Avatar
I have had my 1998 Tans Am for 6 years and have had the following problems:
Headlight Motor Replaced
Motorized Antenna Replaced
The Front Rotors replaced twice and resurfaced twice
Fuel Pump Replaced
Old Aug 4, 2003 | 07:53 AM
01SS346's Avatar
well you might have to replace the rear tires a few times, for some reason they wear faster than the fronts...
Old Aug 4, 2003 | 08:39 AM
BackInBlackWS6's Avatar
98s are notorious for having 3.9 Degrees of knock retard depending on when in the year they were built. It is directly related to the knock sensors put in them, otherwise the 98 is just like the others before 2001 ... missing an LS6 intake and bogged with all the emissions EGR crap. Otherwise, they are great!!
Old Aug 4, 2003 | 09:18 AM
2000TA's Avatar
that would be from giving it too much gas
