6,650 for a 130,000 mile mystic transam
What you guys think A.T. clean but 130,000 miles.
What can go out if i buy ?
tranny?
rear end?
anything else?
A 1999 transam mystic color rare? better or worse than other years?
Future collector?
Best engine v8 G.M. made?
recomended yes or no?
Thinking ?
Tell me Ls-1ers
whats you opinion?
Id rather have a 6 speed?
Input please!!!!!!!
thanx!!
Depends on how it was driven. Yes, mystic is more rare than others, but not worth anything extra (to me at least).
If you buy a 6 speed car, understand that you will need to buy a new rear end at some point. The "best" engine is debatable. Some years had better cams, others had better intakes.
Are you planning on putting in a cam? If so, get an 01/02 that already has the LS6 intake, or you could buy a 99-00 and install one for around 300 bucks . IIRC, the 99-00s have a slightly better cam setup.
Long story short, it's not a "bad" deal for that car, but I would shop around more and get the one you want
98's are a little diffferent than the 99 and later. Some claim they are the worst due to oil pump failures and the pcm being a little a harder to tune. My 98 has 137,454 on it now and no problems. Do a search on LS1tech.com and you will see tons of topics on this
TMV trade in = $6,081, private = $7,279 , dealer = $8,525
from Edmunds (pricing in Fl, probably a little higher in CA). Also, they didn't give an option on mileage but I'd think they are calculating it at roughly 100K for a 1999; that difference is probably balanced with the CA vs FL deal..
So, for the $$ it doesn't sound to bad, unless your set on a manual.. just remember your the customer, set your number and stick to it, they'll always be another don't settel..
persoanlly I'd hold out for t-tops or convertible with lower miles and pay a little more, but that can be hard to find
best of luck
best of luck
oldschool
Feb 9, 2016 09:21 PM
lt1car
Aug 1, 2002 08:32 PM
