4l60e?
Old May 30, 2003 | 02:04 PM
GoFast908Z's Avatar
Member
4l60e?
how much power can the stock 4L60E tranny take?
Old May 30, 2003 | 11:51 PM
99blackSS's Avatar
Originally posted by amood
60 Kajillion HP and 2973.551 Bazillion Ft/Lbs of T.
In that case I need a new tranny.
Old May 31, 2003 | 01:14 AM
GoFast908Z's Avatar
Member
hmmmm...........
Old May 31, 2003 | 11:26 AM
SSpdDmon's Avatar
I'm not 100% on this, but I think the stock A4 is good up to about 400~450hp without modification. If you do things like a Hypertech and up the firmness of the shifts, it's gonna wear out the internals quicker. After that, it's all about upgrading the belts and clutch packs...
Old May 31, 2003 | 11:34 AM
SLPSSLS1's Avatar
I have a 2000 SS A4 with about 400-450 hp, and to tell you the truth I don't trust the tranny. I just made a appointment to get my tranny built at a local shop, i suggest getting a valve kit, tranny cooler, high performnce clutches, and a high perfomance band. It might run you around 600 bucks but it will be well worth it. Then bring on the power.
Old May 31, 2003 | 09:26 PM
kjlvilla's Avatar
GM manuals say:
Maximum engine torque: 475 NM (350 ft lbs)
Maximum Gearbox torque: 910 NM (670 ft lbs)
Hope this helps more than confuses.
Old May 31, 2003 | 09:57 PM
99blackSS's Avatar
Originally posted by kjlvilla
GM manuals say:
Doesn't the engine produce 350 torque stock? So nothing is supposed to be added?
Old May 31, 2003 | 10:25 PM
kjlvilla's Avatar
Don't ask me, the specs. are from the Hydra-Matic 4L60e Technicians Guide (second edition), printed by General Motors Powertrain. I didn't write it, only replied to the note. Although, the 60 is based on "relative torque capacity", sounds like there is some wiggle room.
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
