4.10 4.11 Gear strength
Old May 5, 2003 | 10:47 AM
  #16
rncotton's Avatar
Originally posted by PhantomTA
All the gears for our 10 bolt are 4.10 not 4.11
I beg to differ. I bought a set of Motive 4.11 gears on Friday. I counted the teeth to confirm. They are 4.11's.
Old May 5, 2003 | 12:04 PM
  #17
PhantomTA's Avatar
Moderator
what does it say on the box? and what is the part # on the box
Old May 5, 2003 | 05:54 PM
  #18
BadAndy743's Avatar
Phantom,
I think you should listen to us, as we have direct physical and mathematical experiece in this respect. You are correct about using thicker gears with a 2 series carrier, but that is completely irrelevant in this case, because: we all have a three series carrier(except for some 2.73 schmoes), and the teeth in the 4.11 are lateraly thicker, not the overall thickness of the gear. Yes, the thickness you are referring to would not make the gear stronger.
Bad Andy
Old May 5, 2003 | 08:45 PM
  #19
rncotton's Avatar
I did not get the box back after the install. Had you wanted all the details on Thursday night when I bought the gears, or Friday morning before 7:00 AM when I dropped them off with the installer ... well I could have told you.
I counted the teeth and did the math. They are 4.11 gears. They were made in Italy. They were Motive brand. The box was red and white.
Old May 5, 2003 | 09:28 PM
  #20
BadAndy743's Avatar
Right on , Cotton!
Old May 5, 2003 | 10:48 PM
  #21
AL SS590 M6's Avatar
Moderator
This is good news for those that want the higher ratio without the higher breakage of the 4.10s. The 4.11s thicker gear base will definitely take more guff than the 4.10s.
But I too have never heard of these gears before this thread. Motives made in Italy huh. I'll have to check it out.
Old May 6, 2003 | 06:54 AM
  #22
PhantomTA's Avatar
Moderator
Funny thing is, I sell Motives along with various other gears..
this is the first ive heard of 4.11's as well
Old May 7, 2003 | 11:01 PM
  #23
BadAndy743's Avatar
Damn Whiny 4 series gears!!! I'm gonna try to get mine set up again, after it started howling this week. At least my mechanic is getting a new set of gears to start with instead of readjusting the old ones, which would have worn improperly by now. One more 4.11 in the mail! Second times the charm!
Bad Andy
Old May 7, 2003 | 11:27 PM
  #24
Freak's Avatar
Ive read posts about this before, All the ones Ive read said they were actualy marked as 4.10's, but when the teeth were counted they were actualy 4.11's.
Old May 8, 2003 | 08:03 AM
  #25
rncotton's Avatar
Surprise! Care to guess what I have at home?
My mechanic put all my old grenaded rear parts in a box for me. I didn't even open it up. When I opened it up last night to show the parts to a friend of mine, the Motive box was in there, too.
So ... when I get home this afternoon, I'll get all the info that you wanted.
Old May 8, 2003 | 05:41 PM
  #26
mcflyz28's Avatar
I just received Motive (4.10's) via ups the box does say made in Italy, I have 37 teeth on the ring gear and 9 on the pinion, the part number on the box is G875410, of course the label below that says F890500 ?
Old May 8, 2003 | 08:27 PM
  #27
BadAndy743's Avatar
Hello.. Mcfly!! Anybody home?
Divide 37 by 9 and tell me what you get.
Bad Andy
Old May 8, 2003 | 09:43 PM
  #28
mcflyz28's Avatar
4.11111111
Old May 8, 2003 | 10:39 PM
  #29
BadAndy743's Avatar
Congratulations, you have a 4.11. If it had 41 ring teeth and 10 pinion teeth you would have a 4.10.
Old May 9, 2003 | 07:46 AM
  #30
rncotton's Avatar
Ditto.
