315 on 01 ss
Old Jun 25, 2003 | 06:58 PM
rocketjs's Avatar
315 on 01 ss
I just put a set of 17" x 11" American Racing Torque Thrust II with 315's on the back of my car. I did some banging on the fender well and I noticed that the bump stop on the passenger side is close to the inside of the tire ( about 1/2"). I also noticed that when I had my car on jack stands with the weight off of the rear end the bump stops were hitting the tires. I took the bump stops off and have not put them back on yet. I was wondering if
1. Is 1/2" enought room for the tire to clear
2. Should I grind material off of the bump stops
3. Do I need to get my fenders rolled or flaired
4. Is there a way that I can have my car on jack stands without my tires hitting the bump stops
5. Do I need the stops on my car in the first place
are there any other questions or concerns that I might not know about thank you
Old Jun 25, 2003 | 07:17 PM
stik6shift98's Avatar
i have 315 on my car they are also on a 11 inch rim....and it doesnt hit
i think what helped me out was that i have an adj panhard bar and lca and subframes...
so i would try to get some suspension and see if tht helps you out
and yes u need those bump stops
Old Jun 30, 2003 | 06:05 PM
Cap'n's Avatar
I'm sorry I can't give you any input but I'm glad you asked the question because I plan to put the same rims on my 02 Z when the stock tires need to be replaced. What size did you go with on the front, or did you do the same size all around? Have you taken any pictures yet?
Old Jul 1, 2003 | 08:31 AM
ShaneS's Avatar
Re: 315 on 01 ss
1. Under normal driving conditions, yes.
2. Yes.
3. If you think you might have some tire/fender contact, then I suggest rolling the fenders - much easier than getting them flaired..
4. Put the jack stands under the axle.
5. Yes.
good luck,
Shane
Old Jul 1, 2003 | 02:12 PM
GoFast908Z's Avatar
Member
Here comes the dumb question: What are the bump stops?
Old Jul 1, 2003 | 02:46 PM
they stop the cars suspension from bottoming out....or something like that
Old Jul 2, 2003 | 05:02 PM
rocketjs's Avatar
I put 17" x 9.5" on the front with the stock eagel f1's. no pictures yet but they look good
chuck
Mar 31, 2003 09:58 PM
stik6shift00
Mar 5, 2003 08:34 PM
JTS95TA
Jan 28, 2003 05:43 PM
COMNBYU
Dec 12, 2002 07:31 AM
RS Dragster
Nov 14, 2002 05:09 PM
