3 or 4 Channel ABS??? Ummm.....
Old Aug 10, 2003 | 09:55 PM
Ferocity02's Avatar
Question 3 or 4 Channel ABS??? Ummm.....
I need to buy new axles, since one of mine is bent to crap. There is an option for ABS, which I'm pretty sure I have. But I can get either 3 channel ABS, or 4 channel ABS. I have no idea what they mean or which one I need. My car is a 99 Z28 w/ traction control(ASL). I think there is a light that says "ABS INOP" on the dash, so I should have ABS. On the stock axle there is that gear looking thing with the magnetic sensor right next to it which is bolted to the backing plate.
Anyone wanna tell me whether I need 3 or 4 channel ABS, or just explain what they mean?
Thanks a lot!
Old Aug 10, 2003 | 10:31 PM
96SFLZ's Avatar
Since you have TC (ASR), you've got 4 channel...controls each wheel/brake individually (LF, RF, LR, RR).
With 3 channel, it's just LF, RF and the rear two as one.
Old Aug 10, 2003 | 10:33 PM
Beast96Z's Avatar
If you have traction control, which you do, you have 4 channel. It is nothing more than the number of sensors on the ABS system. In your case, there is a sensor at each wheel. If you don't have TCS, then you just have a single sensor on the center of the rear-end housing on top of the chunk. This makes it 3 channel, or 3 sensors.
IndyZman
Oct 22, 2015 02:17 PM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
Bxlt1
Jul 18, 2015 02:48 PM
