2002 camaro ls1 sputtering??????
Old Jan 26, 2012 | 01:30 PM
tgates's Avatar
2002 camaro z28 m6 93,000 miles
The car has long tubes, NO cats and normal exhaust.Ii noticed the O2 sensor wires are cut on the driverside, passenger side is fine. has NO ENIGINE LIGHT ON and they all work and turn on during start up then go off like normal.
so heres the deal,,,,,,,
while cruising around at low RPMs it starts to sputter and bog. if you floor it, it runs great (like a bat out of hell) and NO engine lights ever come on. could it be the O2 sensor? even if no codes show up? or a TPS?
PLEASE HELP!!
THANKS
Old Jan 26, 2012 | 02:28 PM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
Re: 2002 camaro ls1 sputtering??????
I know LT1s throw codes that don't turn on the SEL light I don't know if LS1s do it but it might be worth a try.
Old Jan 26, 2012 | 03:38 PM
tgates's Avatar
ok ill try that.
Old Jan 30, 2012 | 02:56 PM
6spdpewterZ's Avatar
Exhaust leak maybe? It happened to me when my longntubes where installed..
Old Jan 31, 2012 | 04:37 AM
treyville's Avatar
sounds like MAF, or PCV..start small and work up: air filter, clean MAF or check PCV and hose and leak in exhaust
Old Jan 31, 2012 | 11:31 AM
whitdog54's Avatar
is it tuned?
Old Feb 8, 2012 | 05:40 AM
tgates's Avatar
yes the car had a exhaust leak at the manifold it was really bad but I fix that now, it has not done it since, but there is also an o 2 sensor wire that was cut and it still exposed but I think the car has been tuned because it has no cats and there is no check engine light. it seems to only do it when it was wet out or after I got done spraying the car off.
HCz28
Jan 11, 2015 11:17 AM
ANDYZ28
Dec 29, 2014 09:13 PM
ChrisFrez
Nov 23, 2014 10:33 AM
ChrisFrez
Aug 12, 2002 11:50 AM
