2.73's and a converter?
Old May 17, 2003 | 07:42 PM
Obiwanls1's Avatar
Question 2.73's and a converter?
Hey is anyone running 2.73's and have a 3000 converter? If so how does it run? post up!
Old May 18, 2003 | 03:44 AM
GoFast908Z's Avatar
Member
I don't but a friend does. It runs fine, a little rough though.
If you are thinking about getting one, i'd get some of the basic mods done first. They will be cheaper too.
-Cold Air Induction
-Cutout
-3.42 or 3.73 gears
-Hypertech Power Programmer 3 (some people say it doesn't do anything, but i did it and it helped a lot. It works a lot better on automatics than manuals.)
-Headers
-y-pipe
After all that, i MIGHT consider a convertor. The stock one is pretty good. But you don't need to stall it high! Hold it at like 2000 rpms to launch. It will be fine.
Old May 19, 2003 | 01:54 AM
vulva's Avatar
Best bang for the buck mod you can do....I had a vig 3200 and 2.73's....and some bolt on's (no headers)...car did not run rough at all and went 12.24 @ 111.32...
Joe
Old May 19, 2003 | 07:02 AM
chevy qc's Avatar
from what i've seen, it seems to be a fairly good working way to go. personally i'd deffinitly go with the converter before the gear.
Old May 19, 2003 | 02:21 PM
NZ12'S's Avatar
Unhappy OOPS.BAD IDEA?
I PUT A 2800 IN MY 99 Z AND IN ABOUT 3 WEEKS I NOT LONGER HAD A TRANSMISSION. THE TRANNY SHOP SAID IT EXPLODED AND TOOK OUT THE TRANNY. THE PIECES WENT THRU THE PUMP AND ATE IT DOWN TO NOTHING. I KNOW THIS IS NOTS NORMAL BUT IT SURE HAPPENED AND OF COURSE THE CONVERTER SHOP IS NOT GOING TO ASSUME ANY RESPONSIBLITY. GUESS WHO IS OUT THE 1600 BUCK FOR THE TRANNY REBUILD.
BAWSS1
Old May 19, 2003 | 07:03 PM
GoFast908Z's Avatar
Member
Re: OOPS.BAD IDEA?
BAWSS1
Thats why I'd get other stuff first. A converter is also a big deal to install. Less can go wrong with the other mods.
Old May 20, 2003 | 04:08 AM
GoFast908Z's Avatar
Member
Joe
Isn't that a little slow (mph) for a low 12 sec. pass?
Old May 21, 2003 | 01:14 AM
AL SS590 M6's Avatar
Moderator
Ahhh................. NO check my sig.
Old May 21, 2003 | 02:37 AM
Black98's Avatar
Check sig. I ran 12.8's before the headers and 3.42's. I have the Yank TT3000 for sale if interested.
Old May 22, 2003 | 07:08 AM
98BlueWS6's Avatar
I am interested in the converter. Why is it you have it for sale? Was it installed. E-mail me at SammyNcubs@aol.com
Old May 22, 2003 | 06:17 PM
gillbot's Avatar
I got a Yank 2800 and everyting is fine. No exploded trans or anything. One down side is the cost to replace tires though!
Old May 23, 2003 | 04:55 AM
98BlueWS6's Avatar
how long was it used for, and how much were you wanting for it? E-mail me if you can. Sammyncubs@aol.com
Old May 23, 2003 | 12:23 PM
z top's Avatar
Joe
hey i was just wondering what kind and size tires did you use to get those numbers because i'd think the only way you'd get numbers like that with the mods that you have done is if you were to have used some decently good size slicks.
Old May 23, 2003 | 12:39 PM
Michael Ozorowsky's Avatar
MPH seems right, because he is using a converter. Launches hard, but doesn't climb that hard, that's why MPH is low. It's not an all motor pass exactly. Also, I agree, he must've used some slicks. Theres a guy here in Tulsa who ran an 11.7 without headers. Basically same boltons as this guy ran. He cut a 1.58 60' with like a 4200 stall, LS6 Cam, and a few other things.
2QUIK6
Sep 17, 2016 02:31 PM
95craz28
11
Sep 12, 2015 07:47 AM
USN06
Sep 7, 2015 03:30 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Aug 5, 2015 08:35 AM
