160 Stat
Old May 29, 2003 | 11:15 AM
SSCamaro99_3's Avatar
160 Stat
Anyone's thoughts, good or bad.
Old May 29, 2003 | 11:23 AM
norcalstreet's Avatar
Good. Reduces engine temperature and helps reduce heat soak.
Old May 29, 2003 | 03:09 PM
GoFast908Z's Avatar
Member
You probably will never notice the difference. But it wouldn't hurt anything, unless you lived where it's very cold.
Old May 29, 2003 | 03:15 PM
I figured while installing a cam, I might as well.
Old May 29, 2003 | 10:25 PM
rncotton's Avatar
I've got one, along with tuning to urn the fans on earlier. We put it to the test a while back when we had a dyno-day at Hypertech.
I made two back-to-back runs on the dyno. We fired up the motor and auto-tapped it, monitoring the coolant temp. When it was at 180*, we made the first run and the temp made it up to around 205*
It took about 2 minutes for the coolant temp to drop back to 180*, just by letting the car sit and idle.
G-BODYT56
Jan 14, 2022 11:14 PM
chevy94c
Mar 26, 2016 08:53 AM
tdigger9899
Sep 7, 2015 10:56 AM
Rich_z28
Sep 13, 2002 03:35 PM
jeff94z28
Sep 11, 2002 02:01 PM
