12's
Old Oct 2, 2003 | 09:36 AM
T.V.'s Avatar
Thumbs up 12's
last weekend I ran my car at Lapeer Dragway in Michigan, I had never raced at the strip before.
I had a best time of 13.447 @104, backed up by a 13.474@104 & 13.528@ 105. The car is stock other than a K&N and the free ram air mod. I would like to get it into the 12's without draining my pocketbook. Even as we speak my cousin is trying all he can do to beat me in his Mustang, because I embarassed him at the track. What are some suggestions?
Old Oct 2, 2003 | 09:39 AM
95GRNZ's Avatar
Question
What car do you have? Year? A4? M6? Bit more info, please.
Old Oct 2, 2003 | 09:45 AM
T.V.'s Avatar
2001 a4 2:73
Old Oct 2, 2003 | 10:04 AM
95GRNZ's Avatar
It is pretty easy to get your car to 12's.
Here's what you need: lid, cutout/catback, higher stall and sticky tires.
Maybe not even all of them. Add some LT's and you;ll have no problem.
I'm sure other guys will pitch in w/more suggestions.
TS
Old Oct 2, 2003 | 10:11 AM
T.V.'s Avatar
I want the car to look and sound stock on the street, is it still possible?
Old Oct 2, 2003 | 10:14 AM
Teal94Z's Avatar
Lid, SLP Dual Dual, it will sound stock, and just might get you there
Old Oct 2, 2003 | 10:16 AM
95GRNZ's Avatar
Thumbs up
Add a higher stall and sticky tires and it's done. Sounds and looks pretty much stock.
Old Oct 2, 2003 | 10:24 AM
BigZ28's Avatar
A lid, converter and some tires should get you into the 12's pretty easily. We have our lids on special righ now for $99. I can get you into a TCI 3000 converter and tranny cooler for $519.98. I can get those shipped to your door for $643.98. Add some tires that will hook at the track and you will see some 12's.
Brian
Old Oct 2, 2003 | 10:28 AM
T.V.'s Avatar
Thanks, how long can I expect the rear end to last? Has anyone tried the T/A rear end girdle?
Old Oct 2, 2003 | 10:46 AM
V6toZ28's Avatar
3 years, 33,000 miles and 570 launches ...
Old Oct 2, 2003 | 10:57 AM
T.V.'s Avatar
Good deal, I've only got 14,000 miles on the clock! Is that a guarantee! Ha Ha
Old Oct 2, 2003 | 01:50 PM
Black01_Z's Avatar
I have a girdle and drag radials with a lead foot. Rear is doing good.
Old Oct 2, 2003 | 06:38 PM
Mikie's Avatar
Get those 2.73s out of that car!
Shame on GM for ever putting them there in the first place.
You need at least a 3.42 under there , but I would go ahead and drop a 3.73 in .
Do the gears and exhaust,lid and you will be there.
Old Oct 2, 2003 | 07:06 PM
LBJ's Avatar
LBJ
Get a lid and a power programmer so you can change up the shift points and firm up the shifts and you should be damn close! Iam sure the cold dry air up their will allow you to run 12's with those two mods. If that gets you within a tenth or so then get a catback and you will have your 12's!
Then get ready....you will want mid 12's then low 12's and finally 11's in a street car that is dead reliable and that is very attainable.
My buddy has a 35th A4 with 3.23's, 3200 stall, TR220 cam, mac mid lengths, borla cat back, pulley, lid, 160 thermo... He drives the car all the time no problems and has run a 12.16@110. and that was before the cam! Just waiting for the weather to cool down and Iam sure he will get his 11.xx@114.xx! You can see his car on the front page of Thunderracing's home page.
Hope that gives you some ideas on how fast these cars can be made to go!
Old Oct 2, 2003 | 07:48 PM
Capn Pete's Avatar
Exclamation
One of THE MOST important things:
  • TIRES
If tires alone don't get you there, then for one more single mod, a torque converter would definitely do it (with tires, of course).
Mikie, I'm afraid a set of 3.73's won't do it on their own. I actually had 3.73's in my car for about 2 months earlier this summer, and I went to the track and ran the EXACT same time as posted in my sig, but actually 1 mph slower, and 60' times between 2.0 - 2.1. IMO, that's not much improvement, BUT, if I had have put TIRES on the car, I think I would have hit 12's almost certainly.
However, the gears were Richmond's and they whined like hell, so I got sick of the noise and decided to swap back the factory gears (since I actually do more highway driving than I thought I did?! ) and I'll look at other means of putting power to the ground right now such as tires, LCA brackets, *maybe a TC*, and eventually more motor!!
