12-bolt Rear End Swap from pickup to '98+F-Body??
Have any of you guys ever put a 12 bolt rear end from either a 1/2 or 3/4 ton pickup into a '98 or newer F-body?? If so, do you have any info about cutting the axle and whether or not the ABS can still be used with the new axle?? Thanks in advance!
So what are you going to do for a torque arm?
Dave "Vegatex" English
<'02 Sebring Silver/Ebony Leather Z-28 A4; T-tops, 3.23 gears, ASR.
Mods: Spectacle SFC's/STB, FIPK, de-screened MAF, red calipers, leather shift boot.
96 LT1-powered '76 Vega Wagon, Howell Engine Developments Computer and Harness, Sanderson CC-13HO headers, Be Cool aluminum rad w/dual 11" SPALS, custom cold air induction, 700r4, Modified 7.5" 10 bolt w/Torsen rear diff, 28-spline Moser Custom Alloy axles, 3.42 rear, '98 Camaro rear disks, cross-drilled and slotted S-10 front disks. 2800 pounds of fuel-injected Whoop-***!>
http://h-body.org/people/projects/building_lt1/index.html
Not sure, this is for my cousins '98 Trans Am. He will have to figure that out i guess. But we need to find him an axle first(if this one from a pickup will work).
Zach~1994 Camaro Z-28; 6-Speed, black/grey; Performance Mods: K&N, Cut Air-box, removed MAF screen, air-foil, no cat, cutout, and Flowmaster;Appearance: Rear blackouts, Tint: Limo Visor, Limo+35% on sides, Limo on Rear; Nice Alarm!; Protected by Passport 8500!
Well, anything can be made to work given enough time and money. I don't think it's a good idea, personally. The current truck isn't the same 12-bolt as was in the 60's big-block Chevelles. Probably would be easier and cheaper in the end to get an aftermarket 12-bolt set up for a torque arm and use the stock brakes, ABS, etc.
Dave
Dave
