1000+ hp
Re: 1000+ hp
a blower isn't just a simple addition to any motor. you can't just have a shop build you a crazy high-compression stroker motor and expect to just add a blower for more power. if you want a SERIOUS blown LS1, you have to make concessions like running a dedicated blower cam and keeping the compression low. plus FI cars are very complex in the way of tuning. i think there's more to this than you realize. 1000+ hp is good for a pass in the 8s...how many 8 second street driven cars do you know of?
also, i hope your not dreaming of going to the gas station and pumping 93 octane into this thing cuz it won't happen.
this would take THOUSANDS of dollars to do.
Re: 1000+ hp
to do a 1000+hp setup as has been said is far from simple or cheap. our current race project has been 2 years in the making and should produce close to 800-900rwhp on the spray. the engine alone if built for a customer would cost about $12,000-$15,000 depending on options. the engine is a 408ci iron block, an FI 427ci setup would cost even more
thecareerender
Nov 27, 2007 03:12 PM
