'02 Z28 A4 LS1 stock injector question;
Re: '02 Z28 A4 LS1 stock injector question;
As far as I know, we have 28.8lb injectors.
Just make sure if you are considering going to a larger injector, you check to see what they are rated at. If you look at an SVO 30lb injector, realize it will act like a 36lb-er in our cars because the SVO's are rated at 40psi I believe and our cars push 58psi through the rails.
Jul 4, 2005 05:00 PM
