01 6spd z28 surging when going through the gears
Old Aug 5, 2007 | 05:25 PM
realtimerehab's Avatar
I have a 2001 z28 w/6 spd. 109k on it. Recently started to surge during normal acceleration. Most noticeable in 1-4 gears because of slower speeds. Service engine light flashes sometimes, but can not get any machine to read a code. SES light doesn't stay on and only flashes during highway cruising in sixth gear. Any suggestions.
Old Aug 5, 2007 | 07:36 PM
SSpdDmon's Avatar
Flashing SES = misfires detected
What's done to the car?
Old Aug 5, 2007 | 07:57 PM
Tune, PCM for less, headers back, o2 sims, whisper lid, plugs, wires
Old Aug 5, 2007 | 09:57 PM
SSpdDmon's Avatar
I'd double check to make sure everything is snugged down right, no leaks (intake and exhaust side), etc. Make sure your MAF is clean and O2's are working properly. If you can't trace it mechanically...then, I'd call PCM for Less and let them know what's going on.
Old Aug 5, 2007 | 10:08 PM
MAF looks clean, everything is tight, no leaks from what I can tell. No exhaust leaks that I can hear. I have an off road y pipe. The two o2 sensors that are left, if they went bad wouldn't it throw a code?
Old Aug 6, 2007 | 08:46 AM
SSpdDmon's Avatar
Assuming PCM for Less didn't kill the codes....
Old Aug 8, 2007 | 10:13 AM
FirstYrLS1Z's Avatar
Fuel pump and/or fuel filter?
Check filter first for not being able to pass the proper amount of fuel to satisfy the demand of the injectors.
Last edited by FirstYrLS1Z; Aug 8, 2007 at 10:17 AM. Reason: addedwhat to check first
Noenav
Mar 1, 2019 07:38 AM
TYLER94Z28
Dec 3, 2014 07:05 AM
tds1213
Nov 27, 2014 12:55 PM
Jul 4, 2005 05:00 PM
