Wierd issue
Old Jun 3, 2008 | 02:37 PM
davecamaro1994's Avatar
Wierd issue
I have a strange problem with my camaro. I have taken it to a local mechanic and he cannot fix it and have searched the boards to no avail. Basically if you are idling at a light the rpm's will shoot up to about 3000 and you have to press the break hard or the car wants to take off. I end up throwing it in nuetral when I recongnize it is happening. The car spikes to about 3500 then settles back down to 600. Anyone have any suggestions?
94 Z28 LT-1 350
Borla cat back
K&N cold air induction
160 degree thermostat
chipped
only real engine mods so far
Old Jun 3, 2008 | 03:53 PM
twozs's Avatar
idle control motor?
Old Jun 3, 2008 | 05:00 PM
Might want to add some basic info about the car.... appears from your screen name that its a 94. What engine, what trans, any major mods?
A "signature" saves you the need to type that info with every post.
Old Jun 3, 2008 | 05:01 PM
moroso99's Avatar
mine did that before. it was my floormat. it would somehow get pushed up and press down the gas, i had to literally stand on the brake to keep from hitting the car in front of me. did it acouple of times. but thats probably not your problem...
Old Jun 3, 2008 | 11:43 PM
Fatdog2's Avatar
Sounds like a vacuum leak like I had.When the intake manifold leak was fixed,it went away.Hope this helps.The mechanic also replaced those little hoses that run along side the pass. side of the intake manifold.My02.
Old Jun 6, 2008 | 11:57 AM
heard from some others it sounds like a vacuum problem as well. Could it be the throttle body?
Old Jun 6, 2008 | 08:06 PM
Oxygen454's Avatar
Did you check for vacuum leaks? I have heard of people using the soap spray test but sometimes you can hear or feel for leaks.
Old Jun 10, 2008 | 03:07 PM
not familiar with the soap spray test. what is that?
Old Jun 10, 2008 | 03:49 PM
pcgamer4life's Avatar
Get a bottle of soapy water and spray it where you think there may be a leak. If air bubbles appear, that's your problem.
MyfateZ28
Oct 5, 2015 12:36 PM
rocknroler69
Apr 29, 2015 10:24 PM
sseeya
Apr 9, 2015 06:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
