why do my windows freeze on the inside?
Old Feb 1, 2005 | 04:05 PM
pHEnomIC's Avatar
Whenever its borderline cold, my windows freeze on the interior side and its likea light frosting that is hard as heck to get off and i cant see out of it at all. I get it mostly ony my front and back window. I never saw the insides freeze on any other veichles except my own. Is anything wrong with my car, maybe an air leak or possibly something coolant related? I check my coolant a lot and i havent lost any since i changed my water pump but its still happening. Only other thing i can think of is i did use rainx on the inside and outside. Any ideas?
Old Feb 1, 2005 | 04:09 PM
TraceZ's Avatar
Re: why do my windows freeze on the inside?
rainex on the inside? The regular stuff or the anti-fog?
I'd re-do the inside with rainex anti-fog and see if that stops it.
Old Feb 1, 2005 | 09:26 PM
Frost on the inside is not normal. You have a moisture problem of some kind.
Old Feb 1, 2005 | 10:12 PM
Capn Pete's Avatar
Do you have the heat on full? I always run my car with the HVAC set to Defrost / Floor, and with the temp set somewhere between half and full hot, use the rear defroster when needed (usually only initially when cold) and my windows always stay clear. The '89 Grand Prix I've been driving this winter is bad for the rear window constantly fogging up, but I was in the trunk the other day and noticed that there are some leaks through the floor of the trunk keeping it damp.....that's probably why the back window fogs up on the inside?
Old Feb 2, 2005 | 09:09 AM
cndctrdj's Avatar
thats what it is just alot of moister in the car. a leakey t top or foolboard. i have the same prob in my civic with a leaky windshield
Old Feb 2, 2005 | 09:29 AM
Blownbird355's Avatar
He said foolboard!!
Old Feb 2, 2005 | 02:54 PM
pHEnomIC's Avatar
My rear defogger makes quick work of the stuff on the rear board. The front stays iced for a while. I just remembered i have no antenna right now so that could be a hole to the interior thats about all i can think of.
Old Feb 2, 2005 | 03:12 PM
Originally Posted by pHEnomIC
... I just remembered i have no antenna right now so that could be a hole to the interior thats about all i can think of.
DOH!
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
damnyankee36
Sep 9, 2015 07:06 PM
z28cam1993
Sep 9, 2015 04:08 AM
