who's drilled the wrong rivets on window motor??
Old Mar 1, 2005 | 08:37 AM
Quick96Z's Avatar
So..the directions that came with the window motor just simply say 'drill out the rivets.' Well i did that, and needless to say i will be going to the hardware store to pick up some bolts to replace the rivets that mount the assembly to the door. Don't bother giving me shoebox's site, i have read it before...i read up on it like 2 weeks ago and i thought for sure i would remember just fine. Just out of curiosity, who all has done this?? I ask this mainly so that i feel better about being retarded as i so clearly am. Also, the correct way to fix this poroblem is to just simply replace the rivets with bolts..right??
thanks,
trav
Old Mar 1, 2005 | 08:40 AM
1-bad-z28's Avatar
Re: who's drilled the wrong rivets on window motor??
I don't want to say you are retarded because we all make stupid mistakes, but, I just don't see how you drilled out the wrong ones. I have replaced both of mine and it is a pain in the ***. And, yes, you do just replace the rivets with the bolts.
Old Mar 1, 2005 | 09:01 AM
I know of people that drilled out the wrong rivets before reading my site, but not after.
Old Mar 1, 2005 | 09:05 AM
94droptopz's Avatar
well if nobody else will admit it i will. Ive done it but in my defense i've never read shoebox's website. no big deal just replace with correct size bolts and learn from mistakes.
Old Mar 1, 2005 | 09:07 AM
bdc95ta's Avatar
I know most people don't have acsess to a rivit gun but man it make's intalling them go so quick. Takeing it off is by far the hardest part....hahah I just remembered I broke there rivit gun at school on the very last rivit I needed....I wonder if they ever got it fixed?
Old Mar 1, 2005 | 01:03 PM
Quick96Z's Avatar
in my defense...i read the site like 2 weeks ago and i got over zealous. I just kinda breezed through the site thinking..'this will only take 10 mins, it'll be a cake walk'. Also, i am running on zero sleep, this weekend my girlfriend and i have done:new clutch, oil pan gasket, rear main, spark plugs, 58mm throttle body and a msd coil. After i have done all of this crap the one thing to hold me up from being done with my car is a friggen window motor..little bastard. Apparently using nuts and bolts is just too easy, no, we gotta use rivets. I am only 20 yrs old, i could use a few more grey hairs anyways.
trav
Old Mar 1, 2005 | 01:06 PM
GrdLockV6's Avatar
First time I replaced one I was drilling out the rivits, and my drill bit wouldn't even go through the wrong rivits. I tried drilling them for like 5 minutes straight, then finally realized I was doing the wrong ones.
Old Mar 1, 2005 | 05:10 PM
Z95m6's Avatar
Shoebox's site is a must for drilling out the rivets. I know i would of turned my door into swiss cheese trying to find the right spot. Thanks to his pic i hit the right spot the first time.
Old Mar 1, 2005 | 06:04 PM
MustangEater82's Avatar
hehe I uploaded the pics from shoebox's site to my digital camera and took it with me to the parking garage I did it in.
I drilled on one wrong rivet, but stopped, after I realized I was an idiot, then did more research and got the pics on my camera to look at..
Old Mar 1, 2005 | 07:14 PM
speedbump's Avatar
I have drilled out the wrong rivits before. Well I got 2 out of 3 before i reallized it, amazingly 1 rivit holds the window in place. Im retarded.
Old Mar 2, 2005 | 01:09 AM
Copernicus325's Avatar
Wow, everyone sure is making me nervous I just got my new motor and am getting ready to do the driver side. I work for FedEx and think I might just blow a few pictures up to poster size just to be sure I don't mess this up
Old Mar 2, 2005 | 02:07 AM
94Z28WP's Avatar
Only problem I had was getting the holes drilled in the door at the right spots.. I made a drawing off shoebox's site and took it out but still missed.. Luckily the doors are fiberglass and I was able to use needlenose pliers and make the holes a little bigger... I took the new motor and looked at it at the same angle as the original in the door and I could see where the rivets went so that wasn't really a problem.
warmeck
Feb 2, 2015 12:44 AM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
formula218
Dec 2, 2014 04:27 PM
