Where Can I Find An Underside Hood Shield?
Anyone know where I can look for a sound deadener that goes on the underside of the hood in early camaros? My car misfires in the rain since I've removed it (it was dirty and falling off already) and now I need it back! Junkyard maybe? They're a tad far from where I am just for that part, although if it keeps me from misfires, it might be worth it.
www.ecklerscamaro.com sells them, plug in their part number 735061 ($67). They're in Titusville, FL though near me. Don't know how much one from a dealer is, but you wouldn't have to ship it across the country.
I've already argued with a few people in other posts who seem to believe that it is only a coincidence that my car misfires every single time it rains in the extremely low rain climate of San Diego.
However, I'm willing to discuss whether or not the sound deadener will help the situation. The reason I think it is the sound deadener is because our hoods' fake scoops have little tiny holes around the outer ring and inner ring of the scoops. These holes are right over some crucial spark components (plugs and coil pack). This occured with 2 different sets of wires, but with the same spark plugs. I believe the sound deadener block these crucial areas.
Are you saying that I just need to change plugs or wires because one or two may be sensitive to moisture and the sound deadener can't block off moisture? If not, tell me why you think the sound deadener is not the problem (rain or dry)?
And yes, I do want to start this, if you don't mind putting in your thoughts on it, that is. I'm always up for solving problems (obviously moreso when they are my own ).
Worn out ignition components whether it be the coil packs, plugs, or wires, can easily cause misfires when exposed to moisture. Granted putting a new sound deadener back on the car will keep water from getting in through the top, it won't block moisture from getting in through the bottom. What if you drive through a big puddle or the roads are just wet from a previous rainstorm? I would chase down the problem at hand. You could get a spray bottle and spray the various parts of your ignition system in hopes of duplicating the problem.
You could always go this route:
http://www.secondskinaudio.com/cgi-b...ps&pg=2&_scb=2
They carry lightweight, "spray-on" sound deadeners and thermal insulation.
This is what I'm replacing my factory cockpit insulation, as well as insulation under the hood...
Could I use a multimeter and match the results up with the rest of the wires or match them up to factory specs?
And thanks for the second skin link, I think I may do that as well, it could also be useful for my '70 Camaro resto.
Plug wires can carry 20,000-30,000 Volts. Measuring the resistance of the wire with a multi-meter will not prove anything. You need to subject the wire to 30,000V and see if it arcs to hearby metal or wires..... e.g. run the engine in the dark and look for sparks. Even this might not prove anything, because the voltage required to fire a plug at idle is lower than the voltage required to fire it under heavy load.
An engine should not misfire just because a few components get damp. Cure the real problem.
Well to solve the question on weather it's the insulation or not, you could try a piece of 30# roofing felt mounted over the section of the engine you need covered. IFthat works then you know for sure.
Got to find out what the weak link is. Consider spraying various components of the engine with a fine mist of water, and seeing what part is the most sensitive.
And.... if your hood is leaking, fix that too. But adding the insulation blanket to cure the leak will just lead to a soggy mess that will trap moisture under the hood and contribute to rust. Remove the components of the hood that are leaking, neatly put some sealer in there, and reassemble.
If a few drips from the small openings in the hood cause the engine to misfire, something is not working correctly. Fixing the drips would still leave you with a "weak" component that is overly sensitive to moisture. Small amounts of moisture shouldn't make any difference. Am I saying with absolute certainly that its the plug wire insulation???.... absolutely not.... just emphasizing that they could be the problem, but you will not find out by using a multi-meter.
